Selection Sets working in VB
I don´t know if this is a normal situation:
I have a macro running in VBA that builds a collection of referenced blocks
in a drawing from a selection set. The key of each member in the collection
is the value of one attribute. Later, it uses this collection to rapidly
locate the block in the drawing, based in the value of the attribute. The
macro runs very fast with about 1000 blocks.
But, for other reasons, I have to have this macro running in VB 6. It works,
but very very slow. Is this normal?. Anyone can advise me in other way to
obtain the same result?
Luis León
Caracas, Venezuela
VB applications linked to Acad are always a little slower than VBA applications. It's hard to tell what might speed up/slow down your application as long as I haven't seen your code. Can you place it on the net? I've had the same problem once. What helped me out then was late-binding....
Joeri Tuyn
Put your procedure in an ActiveX DLL, compile it, register it, set a reference to the new DLL and just call it from the VBA host environment.
Joe
This is the sub tha cuases the problem in VB
6:
Private Sub BuildCodCol()
    Dim
ssBlk As AcadSelectionSet
    Dim objBlk As
AcadBlockReference
    Dim Attlist As
Variant
    Dim iCod(1) As Integer
    Dim
vCod(1) As Variant
    Dim CodCat As
String
    Dim index As Integer
    Dim i As
Integer
    On
Error Resume Next
    Set ssBlk =
ThisDrawing.SelectionSets.Add("CodBlk")
    If Err
Then
ThisDrawing.SelectionSets("CodBlk").Delete
Set ssBlk =
Err.Clear
    End If
    iCod(0) = 0: vCod(0) = "INSERT"
iCod(1) = 2: vCod(1) = "CAT-CPA"
ssBlk.Select acSelectionSetAll, , , iCod, vCod
    If ssBlk.Count = 0
Then
        MsgBox "No hay bloques",
vbExclamation
Set ssBlk = Nothing
        Exit
Sub
    End If
index = 0
    For Each objBlk In
ssBlk
        Attlist =
objBlk.GetAttributes
        For i = 0 To
UBound(Attlist)
If Attlist(i).TagString = "CATFICHAIDCAD"
Then
CodCat =
Attlist(i).TextString
Exit For
End If
Next
        ColCod.Add objBlk,
CodCat
        If Err
Then
Err.Clear
objBlk.layer =
"Repetido"
If Err
Then
Err.Clear
Dim objLay As
AcadLayer
Set objLay =
ThisDrawing.Layers.Add("TMPDuplicado")
objLay.Color =
acCyan
objBlk.layer =
"TMPDuplicado"
End If
        End
If
    Next
    Set ssBlk =
Nothing
End Sub
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
VB
Joeri Tuyn
