Selection Set two different string filter
grobnik
grobnik
Hi to everybody.
Please could you help me with Selectionset Functionality Filter.
I would like to search two different string with selection set, in case adding wild cards.
The main issue concern the LOGIC OPERATOR "OR" to be used or not.
Thank you
    Set MySelection = ThisDrawing.SelectionSets.Add("PP1")
    filterType(0) = -4
    filterData(0) = "<OR"
    filterType(1) = 0
    filterData(1) = "Text"
    filterType(2) = 2
    filterData(2) = "STRING 1"
    filterType(3) = 0
    filterData(3) = "Text"
    filterType(4) = 2
    filterData(4) = "STRING 2"
    filterType(5) = -4
    filterData(5) = "OR>"
MySelection.Select acSelectionSetAll, , , filterType, filterData
Ed__Jobe
Is it not working? You haven't really said what the problem is.
You can use wildcards. Just precede the wildcard with a backwards apostrophe, e.g. "`*test". It's key is usually to the left of 1.
Also, I wrote this sub to make it easier to create complex filters.
Public Sub BuildFilter(typeArray As Variant, dataArray As Variant, ParamArray gCodes())
    'Purpose
    'Fills a pair of variants with arrays for use as a selection set filter
    'Arguments
    'Two variants (not variant arrays) and an unlimited number of group code / value pairs
    'Example
    'BuildFilter fType, fData, 0, "LINE", 7, "WALLS"
    Dim fType() As Integer, fData()
    Dim index As Long, i As Long
    index = LBound(gCodes) - 1
    For i = LBound(gCodes) To UBound(gCodes) Step 2
        index = index + 1
        ReDim Preserve fType(0 To index)
        ReDim Preserve fData(0 To index)
        fType(index) = CInt(gCodes(i))
        fData(index) = gCodes(i + 1)
    Next
    typeArray = fType: dataArray = fData
End Sub
Sub test1()
  Dim fType As Variant, fData As Variant
  BuildFilter fType, fData, -4, "<OR", _
                               0, "TEXT", 2, "STRING 1" _
                               0, "TEXT", 2, "STRING 2" _
                            -4, "OR>"
End Sub
Sub test2()
  BuildFilter fType, fData, 0, "TEXT", 2, "STRING `?"
End Sub
Ed
How to post your code.
grobnik
@Ed__Jobe Thank you for your code but seems that several string will be found and not only STRING 1 or STRING 2.
I'm using wildcards selecting all STRING 1 that begins with "STR*" or "STRI*".
Thank you
Ed__Jobe
In test1, Only "STRING 1" or "STRING 2" will be matched since no wildcards are used.
In test2, "STRING ?" matches a single character.e.g. "STRING A" or "STRING 9". "STRING #" matches a single digit. e.g. 0-9, but not 10-99.
Ed
