Selection set filter
Message 1 of 8
Anyone have a link or site displaying all the filter codes for selection sets?
Replies (7)
Message 2 of 8
F1
GROUP CODES
wrote in message news:5868060@discussion.autodesk.com...
sets?
Message 3 of 8
Sorry, but I don't see it in the help section. The only thing that I saw was XRecord object.
Message 4 of 8
wrote in message news:5869277@discussion.autodesk.com...
XRecord object.
did you look in developer help?
the menu depends a little on your version of acad but should be something
like:
Help|additional resources|developer help
from acad help:
under Group codes for entities
-1
APP: entity name (changes each time a drawing is opened)
not omitted
0
Entity type
not omitted
5
Handle
not omitted
102
Start of application-defined group
"{application_name" (optional)
no default
application-defined codes
Codes and values within the 102 groups are application-defined
(optional)
no default
102
End of group, "}" (optional)
no default
102
"{ACAD_REACTORS" indicates the start of the AutoCAD persistent reactors
group. This group exists only if persistent reactors have been attached to
this object (optional)
no default
330
Soft-pointer ID/handle to owner dictionary (optional)
no default
102
no default
102
"{ACAD_XDICTIONARY" indicates the start of an extension dictionary
group. This group exists only if an extension dictionary has been attached
to the object (optional)
no default
360
Hard-owner ID/handle to owner dictionary (optional)
no default
102
no default
330
Soft-pointer ID/handle to owner BLOCK_RECORD object
not omitted
100
Subclass marker (AcDbEntity)
not omitted
67
Absent or zero indicates entity is in model space. 1 indicates entity
is in paper space (optional).
0
410
APP: layout tab name
not omitted
8
Layer name
not omitted
6
Linetype name (present if not BYLAYER). The special name BYBLOCK
indicates a floating linetype (optional)
BYLAYER
347
Hard-pointer ID/handle to material object (present if not BYLAYER)
BYLAYER
62
Color number (present if not BYLAYER); zero indicates the BYBLOCK
(floating) color; 256 indicates BYLAYER; a negative value indicates that the
layer is turned off (optional)
BYLAYER
370
Lineweight enum value. Stored and moved around as a 16-bit integer.
not omitted
48
Linetype scale (optional)
1.0
60
Object visibility (optional): 0 = Visible; 1 = Invisible
0
92
Number of bytes in the proxy entity graphics represented in the
subsequent 310 groups, which are binary chunk records (optional)
no default
310
Proxy entity graphics data (multiple lines; 256 characters max. per
line) (optional)
no default
420
A 24-bit color value that should be dealt with in terms of bytes with
values of 0 to 255. The lowest byte is the blue value, the middle byte is
the green value, and the third byte is the red value. The top byte is always
0. The group code cannot be used by custom entities for their own data
because the group code is reserved for AcDbEntity, class-level color data
and AcDbEntity, class-level transparency data
no default
430
Color name. The group code cannot be used by custom entities for their
own data because the group code is reserved for AcDbEntity, class-level
color data and AcDbEntity, class-level transparency data
no default
440
Transparency value. The group code cannot be used by custom entities
for their own data because the group code is reserved for AcDbEntity,
class-level color data and AcDbEntity, class-level transparency data
no default
390
Hard-pointer ID/handle to the plot style object
no default
284
Shadow mode
0 = Casts and receives shadows
1 = Casts shadows
2 = Receives shadows
3 = Ignores shadows
Message 5 of 8
I am a little new to the whole help section. Please tell me how to access the developer's help section.
Message 6 of 8
this example filters all lines on layer "layer1"
Sub filterexample()
Dim mode As Integer
mode = acSelectionSetAll
Dim gpCode(0 To 1) As Integer ' 2 types of filters
Dim dataValue(0 To 1) As Variant '2 types of filter data
gpCode(0) = 0: dataValue(0) = "LINE" 'gpcode 0 is used for entity type first filter is to select all lines
gpCode(1) = 8: dataValue(1) = "Layer1" ' gpcode 8 used for entity layer second filter is everything on Layer1
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode: dataCode = dataValue
Set ssetObj = ThisDrawing.SelectionSets.Add("filtrthese")
ssetObj.Select mode, , , groupCode, dataCode
MsgBox "filter contains " & ssetObj.count & " objects"
End Sub whoops now i see you were just asking for a list of codes
Message 7 of 8
wrote in message news:5869360@discussion.autodesk.com...
thought I did 🙂
depending on version...something like:
(menu items at top of acad window)
Message 8 of 8
Thanks for the replies 🙂
