Calling Keyboard Shortcuts?
Is there anyway in visual basic to call keyboard shortcuts, for instance if i wanted to create a Copy Button, is there anyway to simply program the code to input "ctrl + c" to call the copy command within autocad? Thanks for any help in advance!
i don't have an answer to your question, however the clipboard object is accessible for example:
Dim objClip As New DataObject
Dim myText as String
objClip.SetText myText
objClip.PutInClipboard
AutoHotkey is a useful program for easily mapping keys
"ctrl+c" calls the copyclip command which create a temp drawing in your temp directory -
next time you call copyclip the last temp dwg gets deleted and a new one is created. If you
want to copy an entitiy within the drawing use the entity's copy method - if you need to copy
object to another drawing you could use the CopyObjects method.
wrote in message news:5867818@discussion.autodesk.com...
"Sendkeys" maybe?
dgorsman
Keep in mind, not all users will have the same set-up - you cannot guarantee that cntrl-c will *always* invoke the same command.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
