Selecting objects on current layout
All,
I have written a function that selects all objects and filters them against the OwnerId property to determine that they relate to the current active layout and returns all true objects as a collection. The problem I am having is that the objects in other paper space layouts are being returned in the collection. It appears as that all objects in paperspace, regardless of the layout they are present in, are owned by paperspace.
Is there a way to determine what layout an object is really present in ?
Below is the code of my function :
Public Function get_CurrentLayoutObjects() As Collection
'function that gets all objects on active space and
'returns a collection
Dim retval As New Collection
Dim sset As AcadSelectionSet
Dim tempent As AcadEntity
Dim i As Long
On Error Resume Next
ThisDrawing.SelectionSets("temp").Delete
On Error GoTo 0
Set sset = ThisDrawing.SelectionSets.Add("temp")
sset.Select acSelectionSetAll
'Set retval = sset2coll(sset)
For i = 0 To sset.Count - 1
Set tempent = sset.Item(i)
If LCase(ThisDrawing.ObjectIdToObject(tempent.OwnerID).Layout.Name) = _
LCase(ThisDrawing.ActiveLayout.Name) _
Then
retval.Add tempent
End If
Next i
Set get_CurrentLayoutObjects = retval
End Function
You can easily filter by layout by just using
the ObjectID of the Block associated with the
desired layout:
Dim idBlock As Long
idBlock = ThisDrawing.ActiveLayout.Block.ObjectId
For i = 0 to sset.Count - 1
If sset(i).OwnerId = idBlock Then
retval.Add(sset(i))
End If
Next i
"corsoc" wrote in message news:f12aab1.-1@WebX.maYIadrTaRb...
> All,
> Dim i As Long
> On Error GoTo 0
> Then
> retval.Add tempent
> End If
> Next i
> End Function
tony,
could you not also do it in this fashion?
dim x as integer
dim obj as acadentity
For x = 0 To ThisDrawing.ActiveLayout.block.Count - 1
set obj = ThisDrawing.ActiveLayout.block.item(x)
next x
"Tony Tanzillo" wrote in message
news:4D4DBEB0EB4D917FC7148EA78F4672F5@in.WebX.maYIadrTaRb...
> desired layout:
> Dim idBlock As Long
> retval.Add(sset(i))
> End If
> Next i
> > All,
paperspace.
> > Dim i As Long
> > On Error GoTo 0
> > Then
> > retval.Add tempent
> > End If
> > Next i
> > End Function
"Tom Furness" wrote in message news:585F7E231B822329DA0F988D13FE5468@in.WebX.maYIadrTaRb...
> tony,
> dim x as integer
> next x
Yes.
