Selecting from ListBox
Hi, all. Happy New Year.
Rather like "Undo" on the Standard toolbar (when displayed horizontally!) I would like to have a ListBox in a userform that has the top item selected; when the user picks, for example, item 4 from the list all intermediate items from the top down are also selected. Is this (easily) possible?
S
fxcastil
see attached
Fred Castillo
Fred,
Thanks for your reply. Although your LISTBOX does what's required if I double-click an item of the list I can still deselect an item between the top one and my initial selection. This can't be allowed as all items in the list are related... item 5 can't proceed without items 1 through 4 happening first. Therefore if my second selection is item 3 then items 1, 2 and 3 remain selected and items 4 and 5 are deselected.
I've tried modifying your 'ListBox1_DblClick' sub but haven't got anywhere with it yet.
S
Try this....
Private Sub ListBox1_Mouseup(ByVal Button As Integer, ByVal Shift As
Integer, ByVal X As Single, ByVal Y As Single)
Dim I As Integer
Dim J As Integer
With ListBox1
I = .ListIndex
For J = 0 To .ListCount - 1
.Selected(J) = False
Next
For J = 0 To I
.Selected(J) = True
Next
End With
End Sub
wrote in message news:5053589@discussion.autodesk.com...
Fred,
with it yet.
S
Jeff,
I think I can see what this code is supposed to do - deselect everything then reselect 0 > i - but nothing is happening. Just single selections...?
S
To yake it a step further, this allows the deselection of an item and also
allows the use of keyboard entry.
Option Explicit
Private Sub ListBox1_KeyUp(ByVal KeyCode As MSForms.ReturnInteger, ByVal
Shift As Integer)
List_Select ListBox1
End Sub
End Sub
Private Sub UserForm_Initialize()
Dim I As Integer
For I = 0 To 10
ListBox1.AddItem "Item " & I
Next
ListBox1.MultiSelect = fmMultiSelectMulti
End Sub
Function List_Select(ListBox As ListBox)
Dim I As Integer
Dim J As Integer
With ListBox
I = .ListIndex
If .Selected(I) = True Then
Next
For J = 0 To I
.Selected(J) = True
Next
Else
For J = I To .ListCount - 1
Next
End If
End With
End Function
"Jeff Mishler" wrote in message
news:5053577@discussion.autodesk.com...
Try this....
Now that one did the business! Thanks, Jeff.
S
