Selecting and accessing text objects
The help file shows how to create a piece of text, then change some of it's properties, such as alignment. It does not show how to select an existing piece of text through code (no user intervention needed).
I have written something that selects some text objects from the modelspace collection based on some search criteria (layer, color, etc.). I have these objects in an array of type AcadEntity, but I can't find a way to access the .alignment or .rotation for these because they are not defined as text objects.
Is there a way to convert an AcadEntity to an AcadText object? Or is there some other way to select text as AcadText objects?
Any help on this would be greatly appreciated.
If you are confident that the object is AcadText, but declared as
AcadEntity, you can still use the properties (just no IntelliSense). Or you
can cast them:
Sub Test()
Dim myObj As AcadEntity
With ThisDrawing.ActiveLayout.Block
Set myObj = .Item(.Count - 1) ' assumes last object is text object
Debug.Print myObj.TextString
End With
If TypeOf myObj Is AcadText Then
Dim myText As AcadText
Set myText = myObj
Debug.Print myText.TextString
End Sub
R. Robert Bell
wrote in message news:5088211@discussion.autodesk.com...
objects.
I am still having a little trouble with this. Here is what I am attempting.
I am in a loop through the model space collection. Element I matches all my criteria, I just have to test that it is actually Text, then I want to, using some conditions, middle justify it and change it's alignment.
If TypeOf ThisDrawing.ModelSpace.Item(I) Is AcadText Then
Set aTextObject = ThisDrawing.ModelSpace.Item(I)
aTextObject.Alignment = acAlignmentMiddleCenter
aTextObject.Rotation = aTextObject.Rotation + PI
endif
The first line does not seem to work for this (does not stop at text).
When I force it through this the Set line gives me an error.
Do you have any suggestions, or is there some other approach I should be using to do this?
This is how I'd do it.....
Dim oEnt as AcadEntity
Dim oTxt as AcadText
For Each oEnt in ThisDrawing.ModelSpace
If TypeOf oEnt is AcadText Then
Set oTxt = oEnt
oTxt.Alignment = acAlignmentMiddleCenter
oTxt.TextAlignmentPoint = oTxt.InsertionPoint
oTxt.Rotation = oTxt.Rotation + PI
oTxt.Update
Next
HTH,
Jeff
wrote in message news:5088617@discussion.autodesk.com...
