Access draworder via VBA after command has run
I have some code to try and handle xref insertions into our company
drawings. The first part of the code works as expected, waits for a command
to be issued, checks for layer, sets it if the layer exists, creates it if
not. What I am then trying to do is use the sendcommand function to attempt
to send the newly attached xref to the back via draworder. I know this code
won't work as it will attempt to do this before the xref is attached and
will send the last object added to the back. But I am unsure of how to issue
the command after xref command has been completed.
Any help would be greatfully appreciated.
p.s I am a novice at this stuff so be gentle with the programming lingo...
Chris
Option Explicit
' set the public object current Layer to be an AutoCAD Layer
Public objCurrentLayer As AcadLayer
' set the public object Previous Layer to be an AutoCAD Layer
Public objPreviousLayer As AcadLayer
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
' Save the current / active AutoCAD layer
Set objPreviousLayer = ThisDrawing.ActiveLayer
' Check for the folowing cases of the AutoCAD command.
Select Case CommandName
' check for AutoCAD Xref commands..
Case "XREF"
If Not ThisDrawing.ActiveLayer.Name = "0" Then
Set objCurrentLayer = ThisDrawing.Layers.Add("0")
objCurrentLayer.color = acWhite
objCurrentLayer.LayerOn = True
objCurrentLayer.Freeze = False
objCurrentLayer.Lock = False
ThisDrawing.ActiveLayer = objCurrentLayer
ThisDrawing.SendCommand "draworder" & vbCr & "l" & vbCr & vbCr & "back" &
vbCr
' end of if checking for 0 being the current layer.
End Select
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
' Check for the folowing cases of the AutoCAD command that has just ended.
' check for a match on the following AutoCAD commands
Case "XREF"
' make the current active AutoCAD layer the previously saved layer.
ThisDrawing.ActiveLayer = objPreviousLayer
' clear the objCurrentLayer
Set objPreviousLayer = Nothing
End Select
Set objCurrentLayer = Nothing
' end Private Sub AcadDocument_EndCommand
End Sub
Chris Boyd
Cameron Taylor
www.camerontaylor.co.uk
What version of AutoCAD? Later versions have the AcadSortentsTable for draw
order, so there is no need to use SendCommand. Search this newsgroup, as I
helped some others on this topic in the last year.
R. Robert Bell
"Chris Boyd" wrote in message
news:5088038@discussion.autodesk.com...
Chris
Option Explicit
Case "XREF"
vbCr
End Select
End Sub
Case "XREF"
End Select
End Sub
Chris Boyd
Cameron Taylor
