SelectByPolygon Method (ActiveX) Selectselection set , select all region (objects inside polyline points)
jalal.mousa
jalal.mousa
Hi There,
i have a code that select/set closed polyline and once i extract coordinates i am trying to set selection set but i am getting nothing in line selectionSet.SelectByPolygon acSelectionSetWindowPolygon, pointsArray
i have not copied the entire code so some definitions maybe missing (please ignore)
Dim selectionSet As AcadSelectionSet ' Selection set to store the selected objects
Dim AktIDPt As Variant
'Dim MyDWG As AcadDocument
Dim AcadApp As Object
Dim AcadDoc As Object
Dim ThisDrawing As Object
On Error GoTo ErrorHandler
Set MyApp = GetObject(, "Autocad.Application")
ErrorHandler:
If Err.Description <> "" Then
Err.Clear
Set MyApp = CreateObject("Autocad.Application")
MyApp.Visible = True
Set MyDWG = MyApp.ActiveDocument
Dim index As Integer
Dim ent As AcadEntity
Dim PL, Pl_Save As AcadLWPolyline
Dim points As Variant
MyDWG.Utility.GetEntity ent, pp, "Select Tile / Shpae must be polyline: "
If TypeOf ent Is AcadLWPolyline Then
If ent .closed = True Then
Set PL = ent
Dim v As Variant
v = PL.Coordinates
Dim i As Integer
L = UBound(v)
index = 0
For i = 0 To UBound(v) Step 2
points(index) = v(i)
points(index + 1) = v(i + 1)
points(index + 2) = 0
index = index + 3
Next
points(index) = points(0)
points(index + 1) = points(1)
savepoints = points
Set selectionSet = MyDWG.SelectionSets.Add("MySelectionSet")
Dim mode As Integer
Dim pointsArray() As Double
mode = acSelectionSetWindowPolygon
pointsArray = points
**Moderator edit: Moved code to code window. Please  use the </> button to access the code window.
Ed__Jobe
You're forgetting basic selection procedures, the difference between a selection window and a crossing window. Help for the SelectByPolygon method explains that you want to use the acSelectionSetCrossingPolygon constant.
Ed
How to post your code.
jalal.mousa
Hi Ed,
hope you can help me i am getting error "object variable or with block variable not set" for line
selectionSet.SelectByPolygon mode, pointsArray
i Noticed that first time it runs it return values see screen shot Selection set, does that means i need to delete selection set everytime it runs ?
point Array have value see screen shot attached
also autocad attached
are you able to advise what is the issue. below full updated code i am using
Sub Get_List_of_regions_in_Room()
Dim Test As Boolean
Dim Flooringshape1 As AcadEntity
Dim sarea As Double
Dim Slength As Double
Dim pp As AcadLWPolyline
Dim Flooringshape As AcadEntity
ErrorHandler:
Err.Clear
' select poly Line
If ent.closed = True Then
Set Room = ent
Set Flooringshape1 = Room
Test = True
If TypeOf Flooringshape1 Is AcadCircle Then
Set Floorcircle = Flooringshape
circleCen(0) = Floorcircle.center(0)
circleCen(1) = Floorcircle.center(1)
circleRad = Floorcircle.radius
ElseIf TypeOf Flooringshape1 Is AcadLWPolyline Then
If Flooringshape1.closed = True Then
Set PL = Flooringshape1
sarea = PL.area
Slength = PL.Length
ReDim points(UBound(PL.Coordinates) + (UBound(PL.Coordinates) + 1) / 2 + 3) As Double
ReDim savepoints(UBound(PL.Coordinates) + (UBound(PL.Coordinates) + 1) / 2 + 3) As Double
Dim Roompoints() As Double
'Dim v As Variant
v = PL.Coordinates
Dim i As Integer
L = UBound(v)
index = 0
index = index + 3
Next
savepoints = points
On Error Resume Next
If Err Then
Err.Clear
Else
selectionSet.Delete
'Set selectionSet = MyDWG.SelectionSets.Add("TEST_SSET2")
Dim mode As Integer
Dim j As Integer
j = ((UBound(v) + 1) / 2 + 1) * 3 - 1
ReDim Preserve pointsArray(0 To j) As Double
'ReDim Roompoints(0 To j) As Double
mode = acSelectionSetCrossingPolygon
pointsArray = savepoints
'For i = 0 To j
'Roompoints(i) = pointsArray(i)
'Next i
'selectionSet.SelectByPolygon mode, Roompoints
MsgBox Err.Description
End Sub
Ed__Jobe
First, please use the </> button to paste your code into a code window. It's hard to read as plain text and looses it formatting.
You can't add a selectionset if it already exists. A method or function should only do one thing. If you try to do too many tasks in the same method inline with the rest of your code, it will be hard to troubleshoot and you will waste effort duplicating code. If you don't develop good programming habits, you will continuously run into error like this. For example, you will often need to select objects, so create a function that does only that and reuse it. Your use of On Error Resume Next is masking the error that the selectionset already exists. Since you get an error, your Set statement fails. You don't need to delete the ss, a good function would just return the existing ss if it already exists.
Public Function AddSelectionSet(SetName As String) As AcadSelectionSet
' This routine does the error trapping neccessary for when you want to create a
' selectin set. It takes the proposed name and either adds it to the selectionsets
' collection or sets it.
    Set AddSelectionSet = ThisDrawing.SelectionSets.Add(SetName)
    If Err.Number <> 0 Then
        Set AddSelectionSet = ThisDrawing.SelectionSets.Item(SetName)
        AddSelectionSet.Clear
End Function
Same problem with trying to get an instance of acad. Keep it in a separate function. When you use On Error Resume Next, it remains in effect until you use On Error GoTo 0. If you don't, you'll never know where other errors are coming from. That's why it's beneficial to keep your code modular, for troubleshooting, you limit errors to the scope of one method.
Public Function GetAcad(Optional ver As String) As AcadApplication
    ' support multiple acad versions.
    'Sample ver for AutoCAD 2023 ' ".24.2"
    Dim acApp As AcadApplication
    Dim clsid As String
    clsid = "AutoCAD.Application"
    If Not ver = "" Then
        clsid = clsid & ver
    Set acApp = GetObject(, clsid)
    If acApp Is Nothing Then
        Set acApp = CreateObject(clsid)
    Set GetAcad = acApp
End Function
Ed
