Select object inside a polyline in VBA EXCEL
cemdagdeviren
cemdagdeviren
Hi everyone,
I have this code
Option Explicit
Sub PickLwPolysAndGetData()
'for Excel sheet managing purposes
Dim MySht As Worksheet
Dim MyCell As Range
'for Autocad application managing purposes
Dim ACAD As AcadApplication
Dim ThisDrawing As AcadDocument
Dim LWPoly As AcadLWPolyline
Dim mtext As AcadMText
' for selection set purposes
Dim ssetObj As AcadSelectionSet
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
'for general variables managing purposes
Dim iRow As Long
Dim LWArea As Double, LWPerimeter As Double, LWLayer As Variant, amtext As Variant
' Autocad Session handling
    On Error Resume Next
    Set ACAD = GetObject(, "AutoCAD.Application")
    On Error GoTo 0
    If ACAD Is Nothing Then
        Set ACAD = New AcadApplication
        ACAD.Visible = True
    End If
    Set ThisDrawing = ACAD.ActiveDocument
' selecting LwPolylines on screen by selelection set filtering method
    ' managing potential selection set exsistence
    Set ssetObj = ThisDrawing.SelectionSets.Item("LWPolySSET")
    If Err Then Set ssetObj = ThisDrawing.SelectionSets.Add("LWPolySSET")
    On Error GoTo 0
    ssetObj.Clear
    'setting filtering critera
    gpCode(0) = 0
    dataValue(0) = "LWPOLYLINE"
    'selecting LWPolylines
    ssetObj.SelectOnScreen gpCode, dataValue
' processing LWPolylines
    If ssetObj.Count > 0 Then
        ' writing sheet headings
        Set MySht = ActiveSheet
        Set MyCell = MySht.Cells(1, 1)
        With MyCell
            .Offset(0, 0).Value = "LWPoly nr"
            .Offset(0, 1).Value = "Layer"
            .Offset(0, 2).Value = "Area"
            .Offset(0, 3) = "Length"
        End With
        'clearing previous written data
        iRow = MySht.Cells(MySht.Rows.Count, 1).End(xlUp).Row
        If iRow > 1 Then MyCell.Offset(1, 0).Resize(iRow - 1, 3).Clear
        'retrieving LWPolys data and writing them on worksheet
        iRow = 1
        For Each LWPoly In ssetObj
            'retrieving LWPoly data
            With LWPoly
                LWArea = .Area
                LWPerimeter = .Length
                LWLayer = .Layer
            End With
            ' writing LWPoly data
            With MyCell
                .Offset(iRow, 0).Value = "LWPoly nr." & iRow
                .Offset(iRow, 1).Value = LWLayer
                .Offset(iRow, 2).Value = LWArea
                .Offset(iRow, 3).Value = LWPerimeter
            End With
            iRow = iRow + 1
        Next LWPoly
    End If
' cleaning up before ending
    ssetObj.Delete
    Set ssetObj = Nothing
    Set ThisDrawing = Nothing
    Set ACAD = Nothing
End Sub
This is not my code. But i did some modify on it. I want to take mtext inside of polylines and add excel to relevant row which is correct polyline area and perimeter.
Thanks for interest.
cemdagdeviren
Problem is solved.
xxfaxx
Could you post the fixed code please???
