Select entity by lineweight
I have a macro that selects lines from a selectionset with certain properties and sets them to 'bylayer' then to a certain layer.
Sub SelHiddenLType()
Dim SS As AcadSelectionSet
Dim fType(2) As Integer
Dim fData(2) As Variant
Dim ssObject As AcadEntity
Dim Count As Integer
Set SS = SSDel("temp")
fType(0) = 0: fData(0) = "line"
fType(1) = 6: fData(1) = "Continuous"
fType(2) = 370: fData(2) = "50" 'this is not working
SS.Select acSelectionSetAll, , , fType, fData
MsgBox SS.Count & " hidden line(s) found"
For Each ssObject In SS
ssObject.Linetype = "BYLAYER"
ssObject.Lineweight = acLnWtByLayer
ssObject.color = acByLayer
ssObject.Layer = "__Contour"
Next ssObject
End Sub
Private Function SSDel(strName As String) As AcadSelectionSet
' Check Selection Set Name
Dim ObjSS As AcadSelectionSet
Dim objSSets As AcadSelectionSets
Set objSSets = ThisDrawing.SelectionSets
For Each ObjSS In objSSets
If ObjSS.Name = strName Then
objSSets.Item(strName).Delete
Exit For
End If
Next
Set ObjSS = objSSets.Add(strName)
Set SSDel = ObjSS
End Function
The problem is that fType(2) = 370: fData(2) = "50" does not detect 0.50 mm lineweight. I've tried changing fType to 371-379 and the fData to -1(ByLayer).
Can someone help?
The value for dxf code 370 must be integer:
fType(2) = 370: fData(2) = 50
or use AutoCAD VBA enum (see Lineweight property
in the Help file)
~'J'~
Thanks for you're reply, but both 50 and acLnWt050 do not work! any other suggestions?
Sorry for the belating,
Yes, you're right, I 'm wrong
Here is an ugly and dirty method to select
all objects entire drawing with using of Lisp
expression in SendCommand (I don't like it)
Option Explicit
Public Sub SelectByLwt()
Dim ss As AcadSelectionSet
On Error GoTo Err_Control
Dim lwt As String
lwt = InputBox(vbCr & "Enter lineweight value" & vbCr & _
"[ as integer number only ]" & vbCr & _
"Or press Enter to set default", "Select by lineweight", "53")
With ThisDrawing
While .SelectionSets.Count > 0
.SelectionSets.item(0).Delete
Wend
' lisp expression to select all objects with this lineweight entire drawing
.SendCommand "(SSGET " & Chr(34) & "X" & Chr(34) & " (list (cons 370 " & lwt & ")))" & vbCr
Set ss = .ActiveSelectionSet
End With
MsgBox "Selected: " & ss.Count & " objects"
Dim ent As AcadEntity
For Each ent In ss
On Error Resume Next
ent.color = acYellow
Next
Err_Control:
If Not Err = 0 Then
MsgBox Err.Description
Err.Clear
End If
End Sub
~'J'~
Rather than use lineweight as a selection filter test for it within the loop:
Dim fType(1) As Integer
Dim fData(1) As Variant
'fType(2) = 370: fData(2) = "50" 'this is not working
If Not ssObject.Lineweight = acLnWt050 Then GoTo skipme
skipme:
Next ssObject
End Sub
That worked, thanks!
