Select Case basics!
Select Case basics!
Message 1 of 14
Select Case basics!
I'm tring to have a dabble with VBA! I'm wanting to create a form with buttons that will change various layer properties. Having a few problems with the Select Case syntax......i'd be extremely helpful if someone could point me in the right direction. (I'm currently getting the error 'Object doesn't support this property or method (Error 438)'). So I believe there's something wrong with my dimensioning?
Many thanks,
Dom
Private Sub cmdLayerState1_Click()
Dim objLayer As AcadLayer
For Each objLayer In ThisDrawing.Layers
Select Case objLayer
Case "layer1*"
objLayer.LayerOn = False
Case "layer222"
objLayer.Plottable = False
Case "layer333"
objLayer.Freeze = True
End Select
Next
Application.Update
End Sub
Replies (13)
Message 2 of 14
Dom,
It should be: Select Case objLayer.Name
Joe
wrote in message news:4997339@discussion.autodesk.com...
Many thanks,
Dom
Case "layer1*"
Case "layer222"
Case "layer333"
End Select
Next
Application.Update
End Sub
Message 3 of 14
Hi Joe,
Many thanks for that I'm new to this VBA game.....I've just bought your book too, and it's proving to be very useful!
One other thing... I was trying to use wildcards eg "Layer1*"....but this doesn't seem to work, is it looking for an exact match?
many thanks
dom
Message 4 of 14
Untested:
What happens if you do something like this:
Case Like "Layer1*"
Matt W
"Children are like TV sets. When they start acting weird, whack them across
the head with a big rubber basketball shoe."
wrote in message news:4997412@discussion.autodesk.com...
Hi Joe,
many thanks
dom
Message 5 of 14
Hi Matt,
It doesn't like it...I'm getting a compile error
cheers
dom
Message 6 of 14
I think I can solve in an around-about way using for example,
Case "F800" To "G"
I'd be interested to know if wild cards can be used.
Many thanks
Dom
Message 7 of 14
You can use this instead of Select Case (this I know works because I use it
all the time).
Matt W
wrote in message news:4997422@discussion.autodesk.com...
Case "F800" To "G"
Many thanks
Dom
Message 8 of 14
A little slip of the fingers I guess.
And here's the code:
[code]
Dim lays As AcadLayers
Dim lay As AcadLayer
On Error Resume Next
Set lays = ThisDrawing.Layers
For Each lay In lays
If UCase$(lay.Name) Like ("LAYER1*") Then lay.LayerOn = False
If UCase$(lay.Name) Like ("LAYER222") Then lay.Plottable = False
Next
[/code]
Matt W
"Matt W" wrote in message
news:4997462@discussion.autodesk.com...
all the time).
Matt W
Case "F800" To "G"
Many thanks
Dom
Message 9 of 14
That'll do the job, Many thanks for your help
Dom
Message 10 of 14
You're welcome.
Matt W
wrote in message news:4997487@discussion.autodesk.com...
Dom
Message 11 of 14
Here is your answer from the VBA helps files, sorry.
Note that Is and Like can't be used as comparison operators in a Select Case
statement.
Joe
Case "F800" To "G"
Many thanks
Dom
Message 12 of 14
Cheers for your help
Dom
Message 13 of 14
Another possible issue:
In your For Each ... loop, when youy set some layers' Freeze to True, you
may want to test if the layer is ActiveLayer or not, if it is, you cannot
set its Freeze to True (you'll get runtime error). Unless you know before
hand that ActiveLayer will not possibaly included, but doing such a test is
always a good practice.
Many thanks,
Dom
Case "layer1*"
Case "layer222"
Case "layer333"
End Select
Next
Application.Update
End Sub
Message 14 of 14
Thanks Norman, I'll bear that in mind.
Cheers,
Dom
