Select all blocks using selection sets
Message 1 of 10
I'm trying to select all blocks on all layers using selection sets. My code is something like this:
ThisDrawing.SelectionSets.Item("VBA").Delete
Set selecao_blocos = ThisDrawing.SelectionSets.Add("VBA")
gpcode(0) = 8: datavalue(0) = "*"
gpcode(1)=????: datavalue(1)=???
selecao_blocos.Select acSelectionSetAll, , , gpcode, datavalue
As you can see I'm already selecting all layers. Now what do I have to put on gpcode a datavalue to select all blocks on the drawing?
Replies (9)
Message 2 of 10
cadffm
https://www.autodesk.com/techpubs/autocad/acadr14/dxf/group_codes_in_numerical_order_al_u05_c.htm
gc 1 you dont need
gc 0 => "INSERT"
But external references (XRefs) are displayd by inserts too, you have to remove this item if you dont want XRef -Blockreferences.
(it is not possible directly in the filterlist - or i dont know how. With Lisp it isn't)
Sebastian
Message 3 of 10
Ed__Jobe
Also, if you are selecting all layers then you don't need to filter that either.
Ed
How to post your code.
Message 4 of 10
Imagine that I want to select all blocks named "TEST_BLOCK1" and "BLOCK_NAME1". Is there a way to create a selection set for this situation?
Message 5 of 10
cadffm
Look for DXF Reference (for example my link) and your Help [F1]
The Blockname is stored in Inserts with DXF Groupcode 2
as Value you can combine multiple names and wildcards.
"BlockTest,Testblock,MyTestblock" (it is not case sensitive)
Note: That isn't working well for dynamic blocks
(Hint for later with other Blocknames: Think about special characters in Blocknames)
Sebastian
Message 6 of 10
Thank you for the tip, I didn't know I could specify multiple names. All my blocks are dynamic and it is working well for now. Is there a workaround for dynamic blocks with which it doesn't work well?
Message 7 of 10
cadffm
"All my blocks are dynamic and it is working well for now"
Is it working well, or NOT?
Please test it with dynamic block inserts after you edit them by dynamic properties like strech, move..
A workaround is
Catch ALL inserts and check every item of them for the effectivename (propertie), remove if not match your Blockname..
Sebastian
Message 8 of 10
Yes, it is working. I just asked in case I receive a drawing that contains blocks where this doesn't work. Thanks for your help 🙂
Message 9 of 10
norman.yuan
With block name as SelectionSet's selecting filter for dynamic block would be problematic, to say the least, as @cadffm pointed out.
In your case, when you say it works, its reason is ONLY because the dynamic block reference's dynamic property or properties is/are not set to a value so that AutoCAD has to dynamically generate an anonymous block definition for this dynamic block reference. In most, if not all, times when a dynamic propery changes, AutoCAD generates an anonymous block definition for the dynamic block reference. That means, a dynamic block reference may, or very likely, have a different name (like *xxxx") from its original dynamic block definition's name. Thus, filtering by name on dynamic block references would fail to select the block references in interest.
Depending on what kind of dynamic properies your dynamic block has, you can try to set the properties to different values and run your "working" code. I gurantee you would find some targeted blcok references are not selected.
So, as @cadffm said, if your target block references are dynamic blocks, you'd better only set filter to Entity name ("INSERT" in your case, but not apply block name filter).
After the selection set gets all the block refernces, you can loop through the selection setand test each selected block referbce by its "EffectiveName" to identify the target block references.
Norman Yuan
Drive CAD With Code
Message 10 of 10
Thank you for the explanation. It was very helpful
