Runtime error
Runtime error
Runtime error
Okay here’s the deal. I have this simple program (for now) that simply gets a few variables, prints them to a text file, starts a new drawing, and runs a LISP routine that simply reads those variables from the text file and presents an alert box that says “HEY! I think It works.” More code will be added to that later, to do a multitude of calculations and draw some “stuff”, but for now this is how I begin most VBA/LISP programs. I have several that work on the same concept, a VBA dialog box (or boxes) collect information, print it to a text file and then a LISP r5outine reads that information and performs the calculations and draws the object(s).
This one works fine but when I close AutoCAD after running it I get this message.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program C:\Program Files\AutoCAD 2002\acad.exe
abnormal program termination
None of the other programs cause this, and I even get it when I have the LISP routine unload the VBA project.
The main VBA code is
[Private Sub CmdOkay_Click()
If CboNumPocks.Value <> "" Then
If CboNumPocks.Value Mod 2 > 0 Then
MsgBox "The number of pockets MUST be an even number.", _
vbExclamation, " Rollover Wheel ERROR!"
CboNumPocks.SetFocus
Exit Sub
Else
IntNumPocks = CboNumPocks.Value
Else
MsgBox "You must enter the desired number of pockets!", vbExclamation, _
" Number of Pockets ERROR."
Exit Sub
If CboRollDia.Value = "" Then
MsgBox "You must enter the desired roll diameter!", vbExclamation, _
" Roll Diameter ERROR."
CboRollDia.SetFocus
Exit Sub
Else
DblRollDia = CboRollDia.Value
If TxtProdLong.Value = "" Then
MsgBox "You must enter the product length!", vbExclamation, _
" Product Length ERROR."
TxtProdLong.SetFocus
Exit Sub
Else
DblProdLong = TxtProdLong.Value
If TxtProdWide.Value = "" Then
MsgBox "You must enter the product width!", vbExclamation, _
" Product Width ERROR."
TxtProdWide.SetFocus
Exit Sub
Else
DblProdWide = TxtProdWide.Value
StrRollWheel = "C:\RollWheel.txt"
IntFileNum = FreeFile
Open StrRollWheel For Output As #IntFileNum
Print #IntFileNum, IntNumPocks
Print #IntFileNum, DblRollDia
Print #IntFileNum, DblProdLong
Print #IntFileNum, DblProdWide
Close
Unload Me
ThisDrawing.Application.Documents.Add ("L.dwt")
ThisDrawing.SendCommand "(if (not C:RollMe)(load ""RollMe"")) RollMe "
End
End Sub]
AND the LISP is
[(defun c:RollMe (/ A B C D File inspt)
(setq File (open "C://RollWheel.txt" "r"))
(setq A (read-line File))
(setq B (read-line File))
(setq C (read-line File))
(setq D (read-line File))
(close File)
(setq Inspt (getpoint "Select center Point; "))
(alert "HEY! I think it's working.")
(command "vbaunload" "h:/VBA Routines/RollOverWheels.dvb")
Any ideas??
Dave. K
Don't know for sure if it's the cause of the problem, but try removing the
"End" statement from your VBA code.
"End" instantly and unconditioanlly clears all variables (see VB help)
including pointers to/from the calling app and usually causes problems.
Gary
End << Remove this statement
Hey Gary, thanks for the try. Unfortuneately the "End" statement was one of my attempts to fix the problem. I deleted it anyway, just to be sure, and no change.
It may help to know that if I run the program in debug and step throught, it I do not get the error on closing. I also do not get it if I do not start a new drawing. May be I'll try starting the new drawing earlier in the program. Anyway Thanks for ths shot.
Dave. K
Dave,
I have lots of code, and have the same message, but
not all the time. We just igonre it.
Chris
Okay
message.
     Runtime Error!
2002\acad.exe
    If
Wheel ERROR!"
        Exit Sub
    Else
        IntNumPocks =
CboNumPocks.Value
Else
    " Number of Pockets
ERROR."
    Exit Sub
    MsgBox "You must
    CboRollDia.SetFocus
    Exit Sub
Else
    MsgBox "You must
    Exit Sub
Else
    MsgBox "You must
    Exit Sub
Else
        Print #IntFileNum,
IntNumPocks
        Print
        Print #IntFileNum,
DblProdLong
        Print
    Close
Unload Me
End
End Sub]
AND the LISP is
  (setq B (read-line
File))
  (setq D
(read-line File))
  (close File)
  (setq Inspt
working.")
Any ideas??
Dave. K
