Runtime error
09:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Okay heres the deal. I have this simple program (for now) that simply gets a few variables, prints them to a text file, starts a new drawing, and runs a LISP routine that simply reads those variables from the text file and presents an alert box that says HEY! I think It works. More code will be added to that later, to do a multitude of calculations and draw some stuff, but for now this is how I begin most VBA/LISP programs. I have several that work on the same concept, a VBA dialog box (or boxes) collect information, print it to a text file and then a LISP r5outine reads that information and performs the calculations and draws the object(s).
This one works fine but when I close AutoCAD after running it I get this message.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program C:\Program Files\AutoCAD 2002\acad.exe
abnormal program termination
None of the other programs cause this, and I even get it when I have the LISP routine unload the VBA project.
The main VBA code is
[Private Sub CmdOkay_Click()
If CboNumPocks.Value <> "" Then
If CboNumPocks.Value Mod 2 > 0 Then
MsgBox "The number of pockets MUST be an even number.", _
vbExclamation, " Rollover Wheel ERROR!"
CboNumPocks.SetFocus
Exit Sub
Else
IntNumPocks = CboNumPocks.Value
End If
Else
MsgBox "You must enter the desired number of pockets!", vbExclamation, _
" Number of Pockets ERROR."
Exit Sub
End If
If CboRollDia.Value = "" Then
MsgBox "You must enter the desired roll diameter!", vbExclamation, _
" Roll Diameter ERROR."
CboRollDia.SetFocus
Exit Sub
Else
DblRollDia = CboRollDia.Value
End If
If TxtProdLong.Value = "" Then
MsgBox "You must enter the product length!", vbExclamation, _
" Product Length ERROR."
TxtProdLong.SetFocus
Exit Sub
Else
DblProdLong = TxtProdLong.Value
End If
If TxtProdWide.Value = "" Then
MsgBox "You must enter the product width!", vbExclamation, _
" Product Width ERROR."
TxtProdWide.SetFocus
Exit Sub
Else
DblProdWide = TxtProdWide.Value
End If
StrRollWheel = "C:\RollWheel.txt"
IntFileNum = FreeFile
Open StrRollWheel For Output As #IntFileNum
Print #IntFileNum, IntNumPocks
Print #IntFileNum, DblRollDia
Print #IntFileNum, DblProdLong
Print #IntFileNum, DblProdWide
Close
Unload Me
ThisDrawing.Application.Documents.Add ("L.dwt")
ThisDrawing.SendCommand "(if (not C:RollMe)(load ""RollMe"")) RollMe "
End
End Sub]
AND the LISP is
[(defun c:RollMe (/ A B C D File inspt)
(setq File (open "C://RollWheel.txt" "r"))
(setq A (read-line File))
(setq B (read-line File))
(setq C (read-line File))
(setq D (read-line File))
(close File)
(setq Inspt (getpoint "Select center Point; "))
(alert "HEY! I think it's working.")
(command "vbaunload" "h:/VBA Routines/RollOverWheels.dvb")
Any ideas??
Dave. K
Runtime Error!
Exit Sub
Else
End If
Else
Exit Sub
End If
CboRollDia.SetFocus
Exit Sub
Else
End If
Exit Sub
Else
End If
Exit Sub
Else
End If
Close
Unload Me
End
End Sub]
AND the LISP is
(close File)
Any ideas??
Dave. K
