Runtime Error when using 'netload' in Command Line, ACAD 2010
Message 1 of 10
Can anyone shed some light on this error message? The loaded file is a .dll written in Visual Basic.NET using Visual Studio 2010.
NETLOAD Cannot load assembly. Error details: System.BadImageFormatException:
Could not load file or assembly 'file:///C:\Documents and Settings\dan\My
Documents\Visual Studio
10\Projects\ClassLibrary1\ClassLibrary1\obj\x86\Release\ClassLibrary1.dll' or
one of its dependencies. This assembly is built by a runtime newer than the
currently loaded runtime and cannot be loaded.
THX,
Dan M.
Replies (9)
Message 2 of 10
Hi Dan,
You are far more likely to find expertise about .NET programming in the
.NET newsgroup compared with here which is a newsgroup for VBA and by
implication VB6.
Laurie Comerford
dan.mcrae wrote:
> Hello,
> THX,
> Dan M.
Message 3 of 10
You can't use Visual Studio 2010 to build AutoCAD .NET applications, unless
you set the target runtime to .NET 3.5, in your project settings.
Also, pay no attention to the resident dunce told you.
This newsgroup is for ActiveX API issues, regardless of what language is
being used.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:[email protected]...
or
THX,
Dan M.
Message 4 of 10
Hi Tony,
I presume you are referring to my post since there aren't any others.
Every time this issue is raised you repeat the same ridiculous advice
based on an inability to read the names of the newsgroups and the other
reality that the expertise for .NET questions is far more likely to be
found in the .NET newsgroup than in a VBA newsgroup.
VBA programmers don't even need to know the significance of the
different .NET programming paradigms which you use to tell people to
write to the wrong newsgroup because these issues don't exist in VBA.
To illustrate the warrant for your distorted viewpoint you should be
able to point to answers to .NET questions in this newsgroup which have
been provided by posters who don't read the .NET newsgroup. Knowing you
won't be able to, I await your usual abuse as a reply.
Go back to your psychiatrist and get some help.
Laurie Comerford
> being used.
Message 5 of 10
I don't even bother reading your posts, because you
don't have the slightest idea what you're talking about,
as you have proven hundreds of times over.
Get lost.
"Laurie" wrote in message
Hi Tony,
Laurie Comerford
> unless
> being used.
Message 6 of 10
Tony,
I have the same issue.
Could you tell me where to find the setting to change runtime version in VS 2010.?
Thanx,
Matej
Message 7 of 10
Norman_Yuan
VS2010 can be used to target .NET 2.0/3.0/3.5/4.0 framework.
Go to your project->Properties. In "Compile" tab (assume you use VB.NET), click "Advanced Compile Options..." button. In the dialog box, you'll find "Target framework" dropdown list.
If you use AutoCAD2007 to 2011, usually, you can target .NET3.5. With Acad 2010, you can also target .NET4.0 with some setting configured in acad.exe.config. But targeting .NET3.x would be safer bet.
By the way, this kind of question would be better posted in .NET forum as Laurie suggested. This forum is mainly for COM API. If you searched .NET forum, you would have found the answer already.
Norman Yuan
Drive CAD With Code
Message 8 of 10
Thank you, Norman - now it works great!!
The reason I posted here was that the google search directed me here.. thanx for the suggestion, anyways.
Message 9 of 10
kylei7449
Thanks so much! I know this is an old post, but your solution of changing to 3.5 worked. Thx.
>Go to your project->Properties. In "Compile" tab (assume you use VB.NET), click "Advanced Compile Options..." >button. In the dialog box, you'll find "Target framework" dropdown list.
>By the way, this kind of question would be better posted in .NET forum as Laurie suggested. This forum is mainly for >COM API. If you searched .NET forum, you would have found the answer already.
Message 10 of 10
I assume you are running the project sample.
To get AutoCAD .NET running with AutoCAD 2010 you need to change the build to 3.5  ,NET
4.0 doesn't work.
Also, you need to make sure 3.5 is installed by looking in REGEDIT
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v3.5 example
For Visual Studio Express 2013.
Make sure //using System.Threading.Tasks; is commented out since that's for later version of .NET?
On Solution Explorer window, right click on reference and delete csharp
Add the DLL of acdbmgd and acmgd only, core is not available.
Right click on these references and make sure Copy Local is false
Under Build, go to Configuration Manager and create a new configuration for x64 - 64 bits
When building there should be no warnings at all about AMD or anything else
Right click on your project in solutions explorer and click properties
Make sure platform is still x64
Under application tab, make sure target framework is .NET Framework 3.5
Build solution...
Go to C:\Program Files\Autodesk\ACADM 2010\acad.exe.config file
and open in notepad
make sure the following code is uncommented
<supportedRuntime version="v3.5"/>
Go to AutoCAD
run netload
select you DLL
and type AdskGreeting
And view extents to see greeting
