The code below is a popup-menu class. Create a class module called
PopupMenu and paste the code in. To use, just use the MouseUp event of a
control and check for right button (2). See the MouseUp example below the
class code to see how it is used. Good luck!
- Lanny
'<<<<<<<<< B E G I N C L A S S C O D E >>>>>>>>>> ... watch for word
wrap!
Option Explicit
Private Type Point
X As Long
Y As Long
End Type
Private Const MF_ENABLED = &H0&
Private Const MF_SEPARATOR = &H800&
Private Const MF_STRING = &H0&
Private Const TPM_RIGHTBUTTON = &H2&
Private Const TPM_LEFTALIGN = &H0&
Private Const TPM_NONOTIFY = &H80&
Private Const TPM_RETURNCMD = &H100&
Private Declare Function CreatePopupMenu Lib "user32" () As Long
Private Declare Function AppendMenu Lib "user32" Alias "AppendMenuA" (ByVal
hMenu As Long, ByVal wFlags As Long, ByVal wIDNewItem As Long, ByVal
sCaption As String) As Long
Private Declare Function TrackPopupMenu Lib "user32" (ByVal hMenu As Long,
ByVal wFlags As Long, ByVal X As Long, ByVal Y As Long, ByVal nReserved As
Long, ByVal hwnd As Long, nIgnored As Long) As Long
Private Declare Function DestroyMenu Lib "user32" (ByVal hMenu As Long) As
Long
Private Declare Function GetCursorPos Lib "user32" (lpPoint As Point) As
Long
Private Declare Function GetForegroundWindow Lib "user32" () As Long
Public Function Popup(ParamArray param()) As Long
Dim iMenu As Long
Dim hMenu As Long
Dim nMenus As Long
Dim p As Point
' get the current cursor pos in screen coordinates
GetCursorPos p
' create an empty popup menu
hMenu = CreatePopupMenu()
' determine # of strings in paramarray
nMenus = 1 + UBound(param)
' put each string in the menu
For iMenu = 1 To nMenus
' the AppendMenu function has been superseeded by the InsertMenuItem
' function, but it is a bit easier to use.
If Trim$(CStr(param(iMenu - 1))) = "-" Then
' if the parameter is a single dash, a separator is drawn
AppendMenu hMenu, MF_SEPARATOR, iMenu, ""
Else
AppendMenu hMenu, MF_STRING + MF_ENABLED, iMenu,
Next iMenu
' show the menu at the current cursor location;
' the flags make the menu aligned to the right (!); enable the right button
to select
' an item; prohibit the menu from sending messages and make it return the
index of
' the selected item.
' the TrackPopupMenu function returns when the user selected a menu item or
cancelled
' the window handle used here may be any window handle from your application
' the return value is the (1-based) index of the menu item or 0 in case of
cancelling
iMenu = TrackPopupMenu(hMenu, TPM_RIGHTBUTTON + TPM_LEFTALIGN +
TPM_NONOTIFY + TPM_RETURNCMD, p.X, p.Y, 0, GetForegroundWindow(), 0)
' release and destroy the menu (for sanity)
DestroyMenu hMenu
' return the selected menu item's index
Popup = iMenu
End Function
'<<<<<<<<< B E G I N M O U S E - U P C O D E >>>>>>>>>> ... watch for
word wrap!
Private Sub lvwLayouts_MouseUp _
(ByVal Button As Integer, _
ByVal Shift As Integer, _
ByVal X As stdole.OLE_XPOS_PIXELS, _
ByVal Y As stdole.OLE_YPOS_PIXELS)
Dim objMenu As PopupMenu
Dim MenuLine As Long
Dim i As Integer
If Button = 2 Then 'Rightbutton
Set objMenu = New PopupMenu
MenuLine = objMenu.Popup( _
"Select All", _
"Clear All", _
"Invert Selections")
Select Case MenuLine
Case 1 'Select All
With lvwLayouts.ListItems
For i = 1 To .Count
.Item(i).Checked = True
Next
End With
Case 2 'Clear All
For i = 1 To .Count
.Item(i).Checked = False
Next
End With
Case 3 'Invert
For i = 1 To .Count
.Item(i).Checked = Not .Item(i).Checked
Next
End With
End Select
CountTotalSelected
End Sub
