Failed to load project from the file
Message 1 of 9
Please someone tell me how to fix my broken project. I was running a
project and crashed my AutoCAD. Now when I open cad I get the error "Failed
to load from the file" isn't that a clearly understandable error. I tried
manually loading the project, and that doesn't work of course. I really
hate to be one of those "When was your last backup?" victims. Any ideas?
Can I import forms modules etc. from a dvb file?
Doc
Replies (8)
Message 2 of 9
Normally the last saved version of the dvb file should still be there. Maybe
the code is still in memory, shut down and restart your computer. Give it a
shot.
JR
"Jade Jacobsen" wrote in message
news:CD0697C1B771738365EE1958A60D66E6@in.WebX.maYIadrTaRb...
"Failed
> Doc
Message 3 of 9
JR,
The last saved version should still be where? Not sure if I'm with you, but
I do have the dvb file in the same location and the same name that it has
always been. I have even tried loading thru tools-macro-vba manager. It
gives me the same error. I was lucky enough to have a backup from a week
ago, and a print out of the code from a day ago. So with some typing, and
memory joggin (pound pound pound) I have pretty much got the code back up to
speed. I would really like to know how to fix this problem though.
thanks,
jade
"JR Walker" wrote in message
news:D3F1F31D28FEF26F3EF6A0B072BAAE83@in.WebX.maYIadrTaRb...
Maybe
a
> shot.
> JR
> "Failed
tried
really
ideas?
> > Doc
Message 4 of 9
Jade,
dvb's can occaisionally become corrupt. Once that happens you are SOL and
just have to hope that you've backed it up recently. When I've had problems
it's always been after doing form layout/creation work.
Before backing up the dvb file it's good to see if you can reopen it first,
otherwise you could overwrite a good backup with a corrupt file.
Another thing you can do is export the individual components (forms,
modules, classes) from the dvb. I created a macro to automate this process.
It creates a folder with the data/time with all of the exported components.
Look for a thread called "VBA project file size bloat!" from march 19/20
Glen
news:162E622E089A2A74930476609322888B@in.WebX.maYIadrTaRb...
> JR,
but
to
> thanks,
> jade
> Maybe
it
> a
> > shot.
> > JR
> > "Failed
> tried
> really
> ideas?
> > > Doc
Message 5 of 9
JR, Glen,
Thanks for your replies. I have a renewed faith in the NG's. I am very new
to programming, and the best help I have received has come from here. Just
seems like I haven't been able to get a response the last few times I wrote.
Thanks again,
Jade
"Glen Albert" wrote in message
news:0AA9B744193150CB0DF693795E5CB205@in.WebX.maYIadrTaRb...
> Jade,
problems
first,
process.
components.
> Glen
> > JR,
> but
has
It
week
and
up
> to
> > thanks,
> > jade
> > Maybe
> it
> > a
> > > shot.
> > > JR
a
> > > "Failed
> > tried
> > really
> > ideas?
> > > > Doc
Message 6 of 9
GLEN,
I just tried your export routine. LOVE IT!
Jade
"Failed
> Doc
Message 7 of 9
It would probably be better if it was put into it's own dvb, I just never
got around to it. It would be easy enough to do that, you could then add a
form that listed all open projects allowing you to select which ones you
wanted to export.
Glen
news:01C79F26C2C58DD59930AEE3ACED2876@in.WebX.maYIadrTaRb...
> GLEN,
> Thanks,
> Jade
> "Failed
tried
really
ideas?
> > Doc
Message 8 of 9
Hi Glen,
I tried to take your idea to the next phase. I got stuck at saving the completed .dvb
file. The following will get you about 90% there, though. You just have to go into VBA
Manager and saveas the newly created .dvb over the original file.
In order for the following to work you will have to do two things first.
1. Create an empty .dvb file, and put it in the folder where you keep all your other
.dvb files.
2. Download Frank Oquendo's CommonDialog.cls from AcadX, and import the class file into
the module where you place the following code.
Option Explicit
Option Compare Text
Sub UnBloat()
Dim ComDlg As New CommonDialog
Dim strVBAfolder as String
Dim Files() As Variant
'Plug in the path to the folder where you keep your .dvb's below.
strVBAfolder = "T:\Acad2000\VBA"
With ComDlg
.DialogTitle = "Select files"
.DefaultExt = "dvb"
.Filter = "VBA Projects (*.dvb)|*.dvb"
.Flags = OFN_EXPLORER Or OFN_ALLOWMULTISELECT Or OFN_HIDEREADONLY
.InitDir = strVBAfolder
If .ShowOpen Then
Files = .ParseFileNames
Else
GoTo NoFilesSelected
End With
Dim objIDE As Object
Dim iCNT1 As Integer
Dim iCNT2 As Integer
Dim strFileName As String
Dim strBuildFile As String
Dim ProjLoaded
Dim objProj As Variant
Dim strFldrName As String
Dim strProjName As String
Dim objFileSys As Object
Dim objComp As Variant
Dim strFileExt As String
Dim strComponents() As String
Dim objRef As Variant
Dim strReferences() As String
Dim strTmpDVBfile As String
Dim objBlankProj As Object
Dim RefExists As Boolean
Set objIDE = Application.VBE
For iCNT1 = LBound(Files) To UBound(Files)
strFileName = Files(iCNT1)
ProjLoaded = False
strProjName = FindProject(strFileName)
If strProjName <> "" Then
Set objProj = objIDE.vbprojects.Item(strProjName)
ProjLoaded = True
If ProjLoaded = False Then
LoadDVB strFileName
Set objProj = objIDE.vbprojects.Item(FindProject(strFileName))
strFldrName = Replace(strFileName, ".DVB", "")
strProjName = objProj.Name
Set objFileSys = CreateObject("Scripting.FileSystemObject")
objFileSys.createfolder strFldrName
iCNT2 = 0
For Each objComp In objProj.vbcomponents
If objComp.Type <> 100 Then
ReDim Preserve strComponents(iCNT2)
Select Case objComp.Type
Case 1
strFileExt = ".bas"
Case 2
strFileExt = ".cls"
Case 3
strFileExt = ".frm"
End Select
strComponents(iCNT2) = strFldrName & "\" & objComp.Name & strFileExt
objComp.Export strComponents(iCNT2)
iCNT2 = iCNT2 + 1
Next
iCNT2 = 0
For Each objRef In objProj.references
ReDim Preserve strReferences(iCNT2)
strReferences(iCNT2) = objRef.fullpath
iCNT2 = iCNT2 + 1
Next
UnloadDVB strFileName
strTmpDVBfile = strVBAfolder & "\Template.dvb"
LoadDVB strTmpDVBfile
'The following line didn't work so I had to resort to using a template .dvb file.
' Set objBlankProj = objIDE.vbprojects.Add(100)
Set objBlankProj = objIDE.vbprojects(objIDE.vbprojects.Count)
objBlankProj.Name = strProjName
For iCNT2 = LBound(strComponents) To UBound(strComponents)
objBlankProj.vbcomponents.Import (strComponents(iCNT2))
Next iCNT2
If iCNT2 = UBound(strComponents) + 1 Then
MsgBox "All components were imported successfully."
Else
MsgBox "Unable to import " & UBound(strComponents) + 1 - iCNT2 & "
components."
objFileSys.deletefolder strFldrName
For iCNT2 = LBound(strReferences) To UBound(strReferences)
RefExists = False
For Each objRef In objBlankProj.references
If objRef.fullpath = strReferences(iCNT2) Then
RefExists = True
Exit For
Next
If RefExists = False Then objBlankProj.references.addfromfile
Next iCNT2
If iCNT2 = UBound(strReferences) + 1 Then
MsgBox "All references were restored successfully."
Else
MsgBox "Unable to restore " & UBound(strComponents) + 1 - iCNT2 & "
references."
MsgBox "Project: " & objBlankProj.Name & " was successfully restored."
UnloadDVB strTmpDVBfile
'The following line doesn't work in VBA.
' objBlankProj.SaveAs strFileName
' If ProjLoaded = False Then UnloadDVB strFileName
Next iCNT1
Set objIDE = Nothing
Set objProj = Nothing
Set objFileSys = Nothing
Set objComp = Nothing
Set objRef = Nothing
Set objBlankProj = Nothing
NoFilesSelected:
Set ComDlg = Nothing
End Sub
Function FindProject(ByVal strFileName As String) As String
FindProject = ""
For Each objProj In objIDE.vbprojects
strBuildFile = UCase(objProj.FileName)
'The next two lines are in place to work around the fact that the project's FileName
property
'was returning a UNC name instead of a drive letter.
strBuildFile = Replace(strBuildFile, "\\FILESERVER\PROJECTS", "T:")
strBuildFile = Replace(strBuildFile, "\\FILESERVER\CHUCK$", "Z:")
strFileName = UCase(strFileName)
If strBuildFile = strFileName Then
FindProject = objProj.Name
Exit For
Next
End Function
Enjoy.
P.S. - Please let me know if you have any problems with this code. I modified it slightly
for this post to make it more generic.
Chuck Gabriel
news:65835CA95251168473352DE13038AD05@in.WebX.maYIadrTaRb...
> wanted to export.
> Glen
Message 9 of 9
Thanks, I'll give it a try.
Glen
"Chuck Gabriel" wrote in message
news:0F86B8A9A6C1FFF62611553E8D234ECA@in.WebX.maYIadrTaRb...
> Hi Glen,
completed .dvb
to go into VBA
all your other
> .dvb files.
class file into
> Option Explicit
> Option Compare Text
> Sub UnBloat()
> With ComDlg
> .DefaultExt = "dvb"
> If .ShowOpen Then
> Else
> End If
> End With
> Dim ProjLoaded
> ProjLoaded = False
> ProjLoaded = True
> End If
> LoadDVB strFileName
> End If
> iCNT2 = 0
> Case 1
> strFileExt = ".bas"
> Case 2
> strFileExt = ".cls"
> Case 3
> strFileExt = ".frm"
> End Select
strFileExt
> iCNT2 = iCNT2 + 1
> End If
> Next
> iCNT2 = 0
> iCNT2 = iCNT2 + 1
> Next
.dvb file.
> Next iCNT2
> Else
> components."
> End If
> RefExists = False
> RefExists = True
> Exit For
> End If
> Next
> Next iCNT2
> Else
iCNT2 & "
> references."
> End If
restored."
> Next iCNT1
> NoFilesSelected:
> End Sub
> FindProject = ""
project's FileName
> property
"T:")
> Exit For
> End If
> Next
> End Function
> Enjoy.
> Chuck Gabriel
never
a
> > wanted to export.
> > Glen
