Return filename only?
Is there an easy way in VBA to return just the filename from a full
path? e.g.:
C:\this\that\theother\filename.dwg -> extract "filename" only?
(Sort of like dos_splitpath in doslib)
Iqbal.
Iqbal,
You can use: ThisDrawing.Application.ActiveDocument.Name (retrieves
just the name)
instead of: ThisDrawing.Application.ActiveDocument.FullName (retrieves
path and name)
or if you want just part the name use:
Mid$(ThisDrawing.Application.ActiveDocument.Name, 5, 1) (counts five
spaces and takes 1 character)
-Josh
Iqbal Lotey wrote:
> Hi,
> path? e.g.:
> Thanks,
> Iqbal.
p.s.- in case the path your looking at isn't the path of the current drawing
( I assumed), then you can use the mid$ function I mentioned last. It will
work with any string.
-Josh
Minkwitz Design wrote:
> Iqbal,
> just the name)
> path and name)
> -Josh
> Iqbal Lotey wrote:
> > Hi,
> > path? e.g.:
> > Thanks,
> > Iqbal.
Hi!Iqbal,
you can use the follwing function for VBA to get the filename only from any
path string.
Actually it's lot more easier to do the same in VB6.0.
'_________________________________
Public Function f_getFilename(ps_str As String) As String
'function to extract the filename from any path
Dim pi_i As Integer
pi_i = 1
While pi_i <> 0
pi_i = InStr(1, ps_str, "\")
ps_str = Right(ps_str, Len(ps_str) - pi_i)
Wend
pi_i = InStr(1, ps_str, ".")
f_getFilename = Left(ps_str, pi_i - 1)
End Function
bye,
P.Murali
Iqbal Lotey <1@2.3> wrote in message news:383C5063.4B943CDB@2.3...
> Hi,
> path? e.g.:
> Thanks,
> Iqbal.
If you are using the "preview" edition of VBA (R14.00) you may have a problem
getting just the file name. I know I did. The ".Name" property would always
return the full path just like the ".FullName" property.
I wrote a small function to take care of the problem until I could upgrade to
R14.01.
At least I think R14.01 fixed it.
I know R2K returns just the file name when you use
"ThisDrawing.Application.ActiveDocument.Name".
1@2.3 (Iqbal Lotey) wrote in <383C5063.4B943CDB@2.3>:
>Hi,
>path? e.g.:
> Thanks,
> Iqbal.
