Restore a view
Restore a view
Restore a view
How do you restore a named view once it's been added? I saved it with
Dim oMyView As AcadView
Set oMyView = ThisDrawing.Views.Add("MyView")
and I can't figure out how to restore it.
TIA
Have a day 😐
Roi Ledford
Roi,
You must use the SETVIEW method
From VBA help :
Sub Example_SetView()
' This example creates a new view.
' It then changes the active viewport to
' the newly created view.
' First, open a sample drawing.
ThisDrawing.Application.Documents.Open "C:\AutoCAD\Sample\campus.dwg"
' Create a new view
Dim viewObj As AcadView
Set viewObj = ThisDrawing.Views.Add("TESTVIEW")
' Set the view characteristics
viewObj.center(0) = 374: viewObj.center(1) = 313
viewObj.width = 450
viewObj.height = 354
' Get the current active viewport
Dim viewportObj As AcadViewport
Set viewportObj = ThisDrawing.ActiveViewport
MsgBox "Change to the saved view.", , "SetView Example"
' Set the view in the viewport
viewportObj.SetView viewObj
ThisDrawing.ActiveViewport = viewportObj
ThisDrawing.Regen True
End Sub
Bernard
ATC
45700 Villemandeur
France
Roi Ledford a écrit dans le message :
9330C81F18EF75B897F30F450E5CA135@in.WebX.maYIadrTaRb...
> TIA
> Have a day 😐
> Roi Ledford
Hi Bernard,
Thanks for the answer and sorry it took so long to get back.
Have a day 😐
Roi Ledford
"For lucky good wash, use Mr. Sparkle!"
"Bernard Flavignard" wrote in message
news:250EC38CF0BF182131161E8890329D99@in.WebX.maYIadrTaRb...
> Roi,
> From VBA help :
> ' Create a new view
> viewObj.width = 450
> End Sub
> Bernard
> ATC
> 45700 Villemandeur
> France
> > TIA
> > Have a day 😐
> > Roi Ledford
