Hi Bernard,
Thanks for the answer and sorry it took so long to get back.
Have a day 😐
Roi Ledford
"For lucky good wash, use Mr. Sparkle!"
"Bernard Flavignard" wrote in message
news:250EC38CF0BF182131161E8890329D99@in.WebX.maYIadrTaRb...
> Roi,
> You must use the SETVIEW method
> From VBA help :
> Sub Example_SetView()
> ' This example creates a new view.
> ' It then changes the active viewport to
> ' the newly created view.
> ' First, open a sample drawing.
> ThisDrawing.Application.Documents.Open "C:\AutoCAD\Sample\campus.dwg"
> ' Create a new view
> Dim viewObj As AcadView
> Set viewObj = ThisDrawing.Views.Add("TESTVIEW")
> ' Set the view characteristics
> viewObj.center(0) = 374: viewObj.center(1) = 313
> viewObj.width = 450
> viewObj.height = 354
> ' Get the current active viewport
> Dim viewportObj As AcadViewport
> Set viewportObj = ThisDrawing.ActiveViewport
> MsgBox "Change to the saved view.", , "SetView Example"
> ' Set the view in the viewport
> viewportObj.SetView viewObj
> ThisDrawing.ActiveViewport = viewportObj
> ThisDrawing.Regen True
> End Sub
> Bernard
> ATC
> 45700 Villemandeur
> France
> Roi Ledford a écrit dans le message :
> 9330C81F18EF75B897F30F450E5CA135@in.WebX.maYIadrTaRb...
> > How do you restore a named view once it's been added? I saved it with
> > Dim oMyView As AcadView
> > Set oMyView = ThisDrawing.Views.Add("MyView")
> > and I can't figure out how to restore it.
> > TIA
> > Have a day 😐
> > Roi Ledford
