Repeat VBA macro commands by right mouse click.
I have a problem with repeat VBA macro commands by right mouse click.
For Example: if we send a command “L” to draw a line, it does repeat if right mouse click again. In VBA macro, Suppose a macro name “test” and macro command under the Manu is “^C^C^C^C_-VBARUN test” so test macro run when I click on the Manu however it’s NOT repeat if we right click of mouse after one operation. Its repeat only till VBARUN & ITS LOST MACRO NAME "test"
Could you please help me to resolve this problem?
I would be greatly appreciated for your help in this stage.
arcticad
You need to place the link into a command
{code}
(defun C:test ()
(vl-vbarun "myModule.test")
(princ)
{code}
(defun botsbuildbots() (botsbuildbots))
Hi Many thanks for reply. Its mean I need to write a LISP program to run VBA macro? I need by mouse right click last VBA commad will repeat ....
arcticad
Yes the command will repeat. the c: tells autocad this is a command.
you can then use your macro to call the command ^c^ctest
You can put all the commands into a .lsp file and load them with appload. put them in the startup suite briefcase.
