Remove Items from selection Set (Novice Question)
Ok, can someone please help me here!!!
Just as an exercise, I am trying to create a Selection Set, and then Remove all Items from the set. Everything seems to work fine until I execute the RemoveItems Method. When I do, I get a "Invalid argument Items in RemoveItems" error.
Can anybody tell me what I am doing wrong here???
Public Sub ChangePath()
Dim SelRefs As AcadSelectionSet
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
Set SelRefs = ThisDrawing.SelectionSets.Add("SEL_REFS")
FilterType(0) = 0
FilterData(0) = "INSERT"
SelRefs.Select acSelectionSetAll, , , FilterType, FilterData
ReDim entObj(0 To SelRefs.Count - 1) As Variant
Dim i As Integer
For i = 0 To SelRefs.Count - 1
Set entObj(i) = SelRefs.Item(i)
Next i
SelRefs.RemoveItems entObj
SelRefs.Delete
End Sub
RemoveItems requires an array of objects, even if it is a single object.
R. Robert Bell
wrote in message news:5059242@discussion.autodesk.com...
RemoveItems" error.
FilterType(0) = 0
Dim i As Integer
Next i
SelRefs.Delete
End Sub
I thought I was creating an array by looping thru and setting entObj(i) each time thru. So I assume this is not considered an array? Or am I referring to it wrong when trying to delete it?
Also, I saw "ReDim" in an example, that is why I used it to declare "entObj(0 To SelRefs.Count - 1)". If I use "Dim" it gives me an error. Is ReDim to be used just as it sounds? To redeclare something if it has already been declared?
Any suggestions on beginner tutorials?
Jon
your array needs to be an 'AcadEntity'
not 'Variant' datatype
gl - Paul
wrote in message news:5059404@discussion.autodesk.com...
been declared?
Jon
fxcastil
Albert,
A good AutoCAD VBA book is Autocad 200x by Joe Stuphin
a few of my favorite links below
http://www.afralisp.co.za/index.htm
http://msdn.microsoft.com/isv/technology/vba/default.aspx
http://visualbasic.about.com/cs/programmingvba/?iam=metaresults&terms=developer+vba
http://www.vbaccelerator.com/home/index.asp
http://www.visualbasicforum.com
http://www.mrexcel.com/board2/index.php?sid=0ebc52e66ae9c23c13f36a4941084890
Fred C
