Reg. Selection Set Error
I want to select all circle form the active drawing so I have found the code as mentioned below from "acadauto.chm" which is used for Active VBA reference programming.
' Create the selection set
Dim ssetObj As AcadSelectionSet
ssetObj = objAcadDoc.SelectionSets.Add("SSET")
Dim gpCode(0) As Integer
Dim dataValue(0) As Object
gpCode(0) = 0
dataValue(0) = "Circle"
Dim groupCode As Object, dataCode As Object
groupCode = gpCode
dataCode = dataValue
ssetObj.Select(AcSelect.acSelectionSetAll, , , groupCode, dataCode)
and I am getting the error as mentioned below : 2nd & 3rd arguments were optional so I don't want that
Invalid argument FilterType in Select
Can anyone tell me what is the wrong with this code ?
Alfred.NESWADBA
are you really running AutoCAD-VBA? (and not VB.NET?)
Because in VBA you have a more problems like using "Variant" instead of "Object" in your lines, using the syntax "Set ssetObj = ..." instead of just "ssetObj = ..."
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
try this
option explicit
Sub CircleSelect()
On Error Resume Next
Set ssetObj = ThisDrawing.SelectionSets.Item("SSET")
If Err Then Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")
On Error GoTo 0
ssetObj.Clear
Dim dataValue(0) As Variant
gpCode(0) = 0
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
ssetObj.Select AcSelect.acSelectionSetAll, , , groupCode, dataCode
MsgBox ssetObj.Count
End Sub
bye
