Refer to an attribute by its tagname
mdhutchinson
Advisor Advisor
mdhutchinson
Can't you refer to an attribute by its tagname... or do I need to use the following instead?
Dim varAttributes As Variant
Dim incAtt As Integer
varAttributes = blkMrk.GetAttributes
For incAtt = LBound(varAttributes) To UBound(varAttributes)
If varAttributes(incAtt).TagString = "CNT#" Then
varAttributes(incAtt).TextString = CStr(CntlNum)
End If
Next
???? "TagName" = TagString ????
wrote in message news:5427563@discussion.autodesk.com...
following instead?
End If
Next
mdhutchinson
Yes... sorry meant to say:
Can't you refer to an attribute by its TagString ...
OK. Yep, that's how I'd do it, but if I were to be using more than 1
attribute I'd use a Select Case in lieu of the If.
wrote in message news:5427617@discussion.autodesk.com...
mdhutchinson
yes... I just answered my question... because it is possible to have duplicate tags in a block...
looping to get the tag and then to change the TextString is the only way... I guess.
Hutch,
I'd advise getting away from duplicate tags in the same block. Some of the
OOTB tools to work on attributes don't handle that situation real well.
R. Robert Bell
wrote in message news:5427623@discussion.autodesk.com...
I guess.
mdhutchinson
agreed... duplicate tags are not a good idea at all..
I am really quite suprised that AutoCAD doesn't prevent it.
