Redefine block vba creates errors in drawings
I have some code that I'm using as a part of a larger project to automate some (tedious) tasks. This code will redefine a block of a given name from a block in a specified file - useful for updating parts when a spec or supplier changes for example.
The function has existed for many years, and got rewritten to accommodate dynamic blocks with visibility states. It works in essence by renaming the target block, making a note of the attributes, dynamic properties and other uniquenesses and then importing the updated block and inserting it with the properties and suchlike of the old ones - then the renamed old blocks are deleted, code below:
Function UpdateBlock(subjdwg As AcadDocument, SourceDrawing As String, Blockname As String) As String
' This sub will update the block references in the target files to those in a specified file.
' Files and blocks are specified in the BlockSelectForm
' updated to work with dynamic blocks
' updatd again to work with non dynamic and dyanmic blocks together
Dim Acadver As String
Dim DestBlock As AcadBlock
Dim HostBlockDef As AcadBlock
Dim DynB As Boolean
Dim FirstFound As Boolean
Dim Layout As AcadLayout
Dim Ent As AcadEntity
Dim BlkRef As AcadBlockReference
Dim BlkList() As Variant
Dim DynBlkList() As Variant
Dim DyBlkProps As Variant
Dim NoOfProps As Integer
Dim PropCnt As Integer
Dim BlkProp As AcadDynamicBlockReferenceProperty
Dim ObjDBX As Object
Dim TempSrcDwg As String
Dim srcBlock As AcadBlock
Dim SrcModSp As AcadBlock
Dim CopyArray() As Object
Dim InsPt(0 To 2) As Double
Dim OldDestBlockName As String
Dim TemplateBlk As AcadBlockReference
Dim BlkCnt As Integer
Dim BlkOwner As AcadBlock
Dim ReplBlk As AcadBlockReference
Dim NoOfNewProps As Integer
Dim NewPropCnt As Integer
Dim ArrayPos As Integer
Dim OrigAtts As Variant
Dim NewAtts As Variant
Dim N As Integer
Dim Report As String
Dim ProptoRead As AcadDynamicBlockReferenceProperty
Dim AllowVal As Integer
Dim pos As Integer
InsPt(0) = 0
InsPt(1) = 0
InsPt(2) = 0
Acadver = Mid(ThisDrawing.GetVariable("acadver"), 1, 2)
On Error GoTo LocalBlockNotFound
Set DestBlock = subjdwg.Blocks.Item(Blockname) 'block to be updated in current acad file
If DestBlock.IsDynamicBlock Then
DynB = True
On Error GoTo GeneralError
pos = 0
For Each HostBlockDef In subjdwg.Blocks
For Each Ent In HostBlockDef
pos = pos + 1
If Ent.ObjectName = "AcDbBlockReference" Then
Set BlkRef = Ent
If UCase(BlkRef.EffectiveName) = UCase(Blockname) Then
If DynB Then
DyBlkProps = BlkRef.GetDynamicBlockProperties
NoOfProps = UBound(DyBlkProps) + 1
If FirstFound = False Then
ReDim BlkList(0 To (NoOfProps), 0)
FirstFound = True
Else
ReDim BlkList(0 To 1, 0)
FirstFound = True
End If 'dynb
Set BlkList(0, UBound(BlkList, 2)) = BlkRef
If DynB Then
For PropCnt = 1 To NoOfProps
Set BlkProp = DyBlkProps(PropCnt - 1)
Set BlkList(PropCnt, UBound(BlkList, 2)) = BlkProp
Next PropCnt
ReDim Preserve BlkList(0 To (NoOfProps), UBound(BlkList, 2) + 1)
Else
ReDim Preserve BlkList(0 To 1, UBound(BlkList, 2) + 1)
End If 'blockname
Next Ent
Next HostBlockDef
On Error GoTo 0
Set ObjDBX = ThisDrawing.Application.GetInterfaceObject("objectdbx.axdbdocument." & Acadver)
On Error GoTo OpenFileFail
'copy source to temp location first
TempSrcDwg = copyfiletotemp(pathname(SourceDrawing), foldername(SourceDrawing))
'open (temp) source file to read block
ObjDBX.Open TempSrcDwg
On Error GoTo SourceBlockNotFound
Set srcBlock = ObjDBX.Blocks.Item(Blockname) 'block used to update current block
Set SrcModSp = ObjDBX.Blocks.Item("*Model_Space")
ReDim CopyArray(0)
Set CopyArray(0) = SrcModSp.InsertBlock(InsPt, Blockname, 1, 1, 1, 0)
'rename destination block -will be deleted
OldDestBlockName = DestBlock.name
DestBlock.name = DestBlock.name & "-tmp!"
'copy array of 1 block into modelspace
'this is just to bring in the definition, it'll be deleted later
ObjDBX.CopyObjects CopyArray, subjdwg.ModelSpace
'assigns this inserted block to a variable - easier to delete later
Set TemplateBlk = subjdwg.ModelSpace.Item(subjdwg.ModelSpace.Count - 1) 'it is last item in modelspace
'go through list of blocks in block list and replace blocks then dynamic properties to what they were before update
For BlkCnt = 0 To UBound(BlkList, 2) - 1
Set BlkRef = BlkList(0, BlkCnt) 'set blockref to be updated (reused)
Set BlkOwner = subjdwg.ObjectIdToObject(BlkRef.OwnerID)
Set ReplBlk = BlkOwner.InsertBlock(BlkRef.InsertionPoint, TemplateBlk.name, BlkRef.XScaleFactor, BlkRef.YScaleFactor, BlkRef.ZScaleFactor, BlkRef.Rotation)
'ReplBlk.InsUnits = BlkRef.InsUnits
ReplBlk.Layer = BlkRef.Layer
ReplBlk.Linetype = BlkRef.Linetype
ReplBlk.LinetypeScale = BlkRef.LinetypeScale
ReplBlk.Lineweight = BlkRef.Lineweight
ReplBlk.PlotStyleName = BlkRef.PlotStyleName
ReplBlk.TrueColor = BlkRef.TrueColor
ReplBlk.Visible = BlkRef.Visible
If ReplBlk.IsDynamicBlock And DynB Then
'synchronise dynamic properties only if both original and replacement blocks are dynamic
'assume default for dynamic will do if original isn't
DyBlkProps = ReplBlk.GetDynamicBlockProperties
NoOfNewProps = UBound(DyBlkProps) + 1 ' number of props may have changed
For NewPropCnt = 1 To NoOfNewProps 'loop through each dynamic property in updated block
Set BlkProp = DyBlkProps(NewPropCnt - 1)
For PropCnt = 1 To (UBound(BlkList, 1)) ' loop through list of stored properties
Set ProptoRead = BlkList(PropCnt, BlkCnt)
If BlkProp.PropertyName = ProptoRead.PropertyName Then ' see what matches property name
If UBound(BlkProp.AllowedValues) <= UBound(ProptoRead.AllowedValues) Then
For AllowVal = 0 To UBound(BlkProp.AllowedValues)
ProptoRead.AllowedValues(AllowVal) = BlkProp.AllowedValues(AllowVal)
Next AllowVal
Else
'number of allowed values of this property are different..
BlkProp.Value = ProptoRead.Value
If BlkProp.Value <> ProptoRead.Value Then
'Failed to set value, possibly due to conflicting allowed values), report it and move on..
Report = "failed to set value " & ProptoRead.Value & " for dynamic property " & ProptoRead.PropertyName & " in block " & Blockname & vbCr
Next
Next
'now update attributes
End If 'isdynamic
If BlkRef.HasAttributes And ReplBlk.HasAttributes Then
'now copy attributes across
OrigAtts = BlkRef.GetAttributes
NewAtts = ReplBlk.GetAttributes
For ArrayPos = 0 To UBound(OrigAtts)
For N = 0 To UBound(NewAtts)
If NewAtts(N).TagString = OrigAtts(ArrayPos).TagString Then
NewAtts(N).TextString = OrigAtts(ArrayPos).TextString
NewAtts(N).StyleName = OrigAtts(ArrayPos).StyleName
NewAtts(N).Height = OrigAtts(ArrayPos).Height
NewAtts(N).ScaleFactor = OrigAtts(ArrayPos).ScaleFactor
NewAtts(N).Alignment = OrigAtts(ArrayPos).Alignment
NewAtts(N).Rotation = OrigAtts(ArrayPos).Rotation
Next N
Next ArrayPos
'delete old block reference
BlkRef.Delete
Next BlkCnt
'remove imported block template
TemplateBlk.Delete
DestBlock.Delete
'synch attributes
subjdwg.SendCommand "Attsync" & vbCr & "n" & vbCr & Blockname & vbCr
subjdwg.Regen acActiveViewport
UpdateBlock = Report & Blockname & " Block updated."
Set ObjDBX = Nothing
removefilefromtemp (TempSrcDwg)
Exit Function
OpenFileFail:
UpdateBlock = "-2 Cannot open Source File " & SourceDrawing & ", is it open/locked?"
Exit Function
LocalBlockNotFound:
UpdateBlock = "0 " & Blockname & " not in this file"
Exit Function
SourceBlockNotFound:
UpdateBlock = "-1 Cannot update block " & Blockname & ", is it not in the source file?"
Exit Function
GeneralError:
UpdateBlock = "-2 Code error in " & Err.Source & " with block " & Blockname & " " & Err.Description
Exit Function
End Function
the problem is that I'm now getting errors in the drawings, which require manual recovery:
Validating objects in the handle table.
Valid objects 19725 Invalid objects 0
Validating objects completed.
Salvaged database from drawing.
Reading handle 22034 object type AcDbDynamicBlockPurgePreventer
Error 13 (eUnknownHandle) Object discarded
Reading handle 2246B object type AcDbBlockRepresentationData
Reading handle 2267F object type AcDbBlockRepresentationData
Reading handle 22893 object type AcDbBlockRepresentationData
Reading handle 22AA7 object type AcDbBlockRepresentationData
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 10200 objects auditedAcDbBlockTableRecord: "*U99"
XData Handle Unknown Null
Pass 1 12100 objects auditedAcDbLine(28661) XData Handle Unknown Null
AcDbPolyline(28663) XData Handle Unknown Null
AcDbPolyline(28665) XData Handle Unknown Null
AcDbPolyline(28666) XData Handle Unknown Null
AcDbPolyline(28667) XData Handle Unknown Null
AcDbBlockReference(2866C)
Pass 1 13600 objects auditedAcDbLine(28FC7) XData Handle Unknown Null
AcDbPolyline(28FC9) XData Handle Unknown Null
AcDbPolyline(28FCB) XData Handle Unknown Null
AcDbPolyline(28FCC) XData Handle Unknown Null
AcDbPolyline(28FCD) XData Handle Unknown Null
AcDbBlockReference(28FD2)
Pass 1 19800 objects audited
Auditing Entities Pass 2
Pass 2 19800 objects audited
Auditing Blocks
257 Blocks audited
Auditing AcDsRecords
Total errors found 13 fixed 13
Erased 5 objects
I'm guessing that simply deleting the 'old' blocks isn't right (line 182 of my code above), as there's now xdata that's attached to it, but how do I find the xdata -it's not something I've really played with..
Is there a better way to do this rather than my somewhat circuitous route that kinda works, but isn't without issues?
any thoughts and advice appreciated..
thanks
G
