Recovery drawing message
danijel.radenkovic
danijel.radenkovic
Hello to all,
According to my previous topic: https://forums.autodesk.com/t5/visual-basic-customization/rename-a-block-amp-purge-the-drawing/m-p/7...
I have made an application which renames block name in the drawing, then make purge and save the drawing.
The problem happens when I try to open the drawing after modification. I am getting the error from the image. I have tested the same application on few other computers and there is no message after opening a drawing. The message is just on my computer.
Do I have something different in AutoCAD settings?
Can you tell me how to avoid a problem of showing the message?
Here is a piece of code:
                For Each objBlock In acDoc.Blocks
                    If objBlock.Name = txtBlockToRename.Text Then
                        objBlock.Name = txtNewBlockName.Text
                        Exit For
                Next
                With acDoc
                    .PurgeAll()
                    .Save()
                    .Close()
                End With
Best regards,
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
sieclaprzemyslaw
Hello!
Did you try to use save option during closing? Close method has optional SaveChanges value. Try this:
With acDoc
   .PurgeAll()
   .Close(True)
End With
I saw in previous thread that you have it - but macro was not working in that time. Maybe you should try it again with working macro.
danijel.radenkovic
@sieclaprzemyslaw wrote:
Hello!
With acDoc
   .PurgeAll()
   .Close(True)
End With
Yes, I have tried. Still the same, showing the message.
danijel.radenkovic
Any new idea why the error happens?
