Recovery drawing message
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello to all,
According to my previous topic: https://forums.autodesk.com/t5/visual-basic-customization/rename-a-block-amp-purge-the-drawing/m-p/7...
I have made an application which renames block name in the drawing, then make purge and save the drawing.
The problem happens when I try to open the drawing after modification. I am getting the error from the image. I have tested the same application on few other computers and there is no message after opening a drawing. The message is just on my computer.
Do I have something different in AutoCAD settings?
Can you tell me how to avoid a problem of showing the message?
Here is a piece of code:
For Each objBlock In acDoc.Blocks If objBlock.Name = txtBlockToRename.Text Then objBlock.Name = txtNewBlockName.Text Exit For End If Next With acDoc .PurgeAll() .Save() .Close() End With
Best regards,
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
