Recognizing existence of a selectionset
How can I detect if a selectionset with a special name exist.
I want to run the commands:
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("SS1")
but maybe,for some reason the selectionset with name "SS1" already exist in the drawing, therefore an error occurs.
any help is appreciated
Now I know:
If ThisDrawing.SelectionSets.Count = 0 Then
Else
On Error Resume Next
ThisDrawing.SelectionSets.Item("SS1").Delete
On Error GoTo 0
End If
That might work, but not always...try:
'going to check for existence of selection set, if it doesn't exist it will
throw an error...trap it
'check for the sel set
Dim selset As AcadSelectionSet
Set selset = ThisDrawing.SelectionSets.Item("SS1")
'if it exists clear it, if not make it
If Not selset Is Nothing Then
selset.Clear
Else
Set selset = ThisDrawing.SelectionSets.Add("SS1")
End If
Matt
Thank Matt for your nice solution. I tried it and it did work. but why do you think my codes may not always work?
Now that I re-read youe post it may work every time.
The more I think about it the more I'm pretty sure yours is as good as mine.
Ignore my post 🙂
wrote in message news:5863764@discussion.autodesk.com...
another good approach:
For Each sset In ThisDrawing.SelectionSets
If sset .Name = "SS1" Then
ThisDrawing.SelectionSets("SS1").Delete
Exit For
End If
Next
ThisDrawing.SelectionSets.Add ("SS1")
