reading Object data in VB
Hi Guys:
i am facing a problem when reading an object data of each feature in autocad 2000, i am writting the code in VB
the code is here,
Public objAcadMap As Object
Public objAcad As autocad.AcadApplication
Public objMapPrjs As Object
Public AcadDoc As autocad.AcadDocument
Dim odTable As odTable
Dim odTables As odTables
Dim AcadDoc As AcadDocument
Dim dwgName As String
Dim odtbl As Object
Dim tab_name As String
Dim lst As ListItem
Dim odTable1 As autocadmap.odTable
Set objAcad = CreateObject("AutoCAD.Application")
If Not (objAcad Is Nothing) Then
Set objAcadMap = objAcad.GetInterfaceObject("AutoCADMap.Application")
dwgName = Text1.Text
Set AcadDoc = objAcad.Documents.Open(dwgName)
AcadDoc.Activate
Set objMapPrjs = objAcadMap.Projects
If (objMapPrjs(AcadDoc).odTables.count > 0) Then
For Each odtbl In objMapPrjs(AcadDoc).odTables
Debug.Print (odtbl.Name)
tab_name = odtbl.Name
MsgBox tab_name
Set lst = Me.ListView1.ListItems.Add(, , tab_name)
Next odtbl
Set odTable1 = objMapPrjs(AcadDoc).odTables.Item("ATTACHMENT")
Else
MsgBox "There is no Object Data available.", vbInformation
End If
End If
End Sub
i am getting an error at set odTable1 = objMapPrjs(AcadDoc).odTables.Item("ATTACHMENT") saying an error as "TYPE MISMATCH" and ATTACHMENT is an layer in map
by removing an items it will pass through but the odtable1 will be nothing
Please guide me for the above case.
Regards
Jagadish
The object type being returned from odTables.Item ... does not match the
data type declared for the variable you are assigning it to. In this case
odTable1 does not match the data type of the return value.
joe ...
wrote in message news:5650771@discussion.autodesk.com...
Hi Guys:
the code is here,
Dim odtbl As Object
Dim lst As ListItem
Set objAcadMap =
AcadDoc.Activate
MsgBox tab_name
Next odtbl
Else
End If
End If
End Sub
Regards
Jagadish
thnx........
then in this case how we can assign odtables to odtable1
can any body guide me
one way would be to change the variable data type to object until you figure
out the exact object data type.
joe ...
wrote in message news:5651978@discussion.autodesk.com...
thnx........
thnx joe........
i have changed the datatype to Object.....it is working fine...i will get back to u if i found as such any
Jagadish
using the generic data type Object will always work when assigning an
object. what it does not do is give you the intellisense associated with the
specific object that it is. just makes things a bit more complicated. i
would still suggest you attempt to get it to a more specific object data
type.
joe ...
wrote in message news:5652109@discussion.autodesk.com...
thnx joe........
Jagadish
