Reading and editing Block Properties Table using VBA
I've got a block with a properties table like the one in the image below. How do I read/edit the active option using VBA?
GilesPhillips
Have a look at the GetDynamicProperties method for the block reference object - this will assign an array containing dyamic properties that can be edited.
ACad, MEP, Revit, 3DS Max
I tried that and wrote the entire array to excel. It doesn't show up
Ed__Jobe
Post your code if you want help with it. It could be that either the array is not getting populated or you are not writing it to xl properly.
Ed
How to post your code.
