Read/Write Dimstyle Properties with VB(A)
Can anyone answer the following question.
(I have searched everywhere, but did not find an answer)
Is it posible to read/write dimstyle properties, like "DIMTXT", "DIMASO" etc. with VB(A) or ObjectARX?
The dimstyle object just shows the general properties.
I don't want to use the "SETVAR's" !!
Hi eenkinformatisering,
What is wring with code like?
Dim v As Variant
v = ThisDrawing.GetVariable("DIMTXT")
ThisDrawing.SetVariable "DIMTXT", v * 3
Regards
Laurie Comerford
[email protected] wrote:
> Can anyone answer the following question. (I have searched everywhere,
> but did not find an answer) Is it posible to read/write dimstyle
> properties, like "DIMTXT", "DIMASO" etc. with VB(A) or ObjectARX? The
> dimstyle object just shows the general properties. I don't want to use
> the "SETVAR's" !!
Hi Laurie,
Thanks for your answer. You're right about the setvar/getvar things. But what I want to accomplish is to go through all the DIMSTYLES in the drawing and adapt them to the Drawing Standard. Off course I can set every DIMSTYLE current one by one and then go through the setvar's/getvar's, but I'd rather itterate through the DimStyleTableRecords.
Thanks again
