Read the drawing units
Message 1 of 8
Is there a way to read the drawing units (the value set with the -DWGUNITS command)? I could not find any API or variable holding this information.
Replies (7)
Message 2 of 8
Ed__Jobe
You can use ThisDrawing.GetVariable and ThisDrawing.SetVariable to read/change these 3 variables:
INSUNITS, INSUNITSDEFTARGET, & INSUNITSDEFSOURCE
Ed
How to post your code.
Message 3 of 8
Thanks for the reply.
Unfortunately we already tried that, and is not what we are looking for. The value in INSUNITS* can be different from the one set with -DWGUNITS
Message 4 of 8
Jedimaster
Are you looking for LUNITS AUNITS?
Message 5 of 8
Jedimaster
Look into class AcUnits under AutoCAD library
acArchitectural
acDecimal
acDefaultUnits
acEngineering
acFractional
acScientific
On second though that is still not what your looking for
Message 6 of 8
Yep, still not what I am looking for. To make clarify it further:
When running the -DWGUNITS command, the following text is displayed in the command window:
Command: -DwgUnits
Drawing units:
1. Inches
2. Feet
3. Millimeters
4. Centimeters
5. Decimeters
6. Meters
Unit for length <3>:
We're interrested in reading that <3> value.
Message 7 of 8
martijn
It's an old topic, but I was looking for the same and I've found it.
<code>
Dim DWGUnits As Integer
DWGUnits = ThisDrawing.GetVariable("INSUNITS")
</code>
Hope this helps any people looking for the same in the future
Message 8 of 8
Jedimaster
Was just working with INSUNITS... weird.
