Read Excel
Read Excel
Read Excel
I have some code which should read an excel file. When I use the buttons my Listbox remains empty. I have loaded the Excel Object Library. What is wrong?
Private Sub CommandButton1_Click()
Dim excelApp As Excel.Application
Dim wbkObj As Workbook
Dim shtObj As WorkSheet
On Error Resume Next
UserForm1.Hide
Err.Clear
Set excelApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set excelApp = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Cannot start Excel", vbExclamation
End
End If
End If
excelApp.Visible = True
Set wbkObj = excelApp.Workbooks.Open("C:\Bob\Test.xls")
Set shtObj = excelApp.Worksheets(1)
UserForm1.Show
End Sub
Private Sub CommandButton2_Click()
Dim i As Integer
Dim txt As String
UserForm1.Hide
Err.Clear
Set excelApp = GetObject(, "Excel.Appication")
ListBox1.Clear
i = 1
txt = shtObj.Cells(i, 2)
Do While txt <> ""
ListBox1.AddItem txt
i = i + 1
Loop
UserForm1.Show
End Sub
Hi Numpty,
Application misspelled
A Caddie.
And the reason you didn't see the error is the "On Error Resume Next" at the
top of CommandButton2_Click(). It is the root of much evil. Get rid of it,
or at least reset the error handler immediately after.you've checked for the
error.
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
wrote in message news:5252497@discussion.autodesk.com...
wrong?
UserForm1.Hide
Err.Clear
If Err <> 0 Then
Err.Clear
If Err <> 0 Then
End
End If
End If
UserForm1.Show
End Sub
Dim i As Integer
Dim txt As String
UserForm1.Hide
Err.Clear
ListBox1.Clear
i = 1
Do While txt <> ""
i = i + 1
Loop
UserForm1.Show
End Sub
Thank you both. I would not have spotted the error AND you will probably save me future effort by being cautious with the "On Error Resume Next". Your help is much appreciated.
Hi
Reading values from Excel is always problematic.you can make use of databse, unless your application demands excel ..
well i have found no mistake in your code but i dint understand why did u call excel in commnad button 1 click event by seeing your code i feel that u r just openning excel file in commandbuttton1 and agian openning excel and reading cell values in command button 2.Can you explain me wt r u doing in command button 1.
Hi Benny
I am fairly new to VBA. I tried to simplfy the read from excel function by splitting the program into two parts - one to open excel and one to read from excel (see attached).
I really don't like the program opening excel and would much prefer it to just read the values. I am think about using a txt file to hold the data. I intend giving this program to many users who may have earlier copies of excel etc. Your thoughts on this would be helpful.
Hi
try this code its working for me.
I had user form and 1 command button and 1 listbox.
I had prepared a excel document j.xls with names in column 2.
Try out this,it should work....Gud luck
Dim Excel As Object
Dim excelSheet As Object
Set Excel = CreateObject("Excel.Application")
Excel.Workbooks.Open FileName:="C:\j.xls", Editable:=True
Excel.Sheets("Sheet1").Select
Set excelSheet = Excel.ActiveWorkbook.Sheets("Sheet1")
Excel.Visible = True
Dim i As Integer
Dim txt As String
ListBox1.Clear
For i = 1 To 10
txt = excelSheet.Cells(i, 2).Value
If txt = "" Then Exit Sub
Next i
End Sub
