Quick Array Question
I have this function which splits a string and converts it to an array. It works fine with numbers, but when the entry becomes text it doesn't seem to work. What is wrong with my code?
IF varpoints = "Double,Array"
Function stringToDblArray(VarPoints)
Dim StrAr() As Variant
VarPoints = VBA.Split(VarPoints, ",")
If IsNumeric(VarPoints) Then
ReDim ptaRr(UBound(VarPoints)) As Double
Dim i As Integer
For i = 0 To UBound(VarPoints)
ptaRr(i) = CDbl(VarPoints(i))
Next i
Else
ReDim StrAr(UBound(VarPoints)) As Variant
StrAr(i) = CStr(VarPoints(i))
Next i
stringToDblArray = ptaRr
End Function
Ed__Jobe
Because of IsNumeric, your logic will never enter the If structure when the argument is text.
Ed
How to post your code.
Change this line
on
ReDim StrAr(UBound(VarPoints)) As String
Will this helps?
~'J'~
I've tried changing from Variant to String and it still gives me an error subscript out of range.
Could i possibly check each index of varpoints before it redim's to see if it is numeric since isnumeric will prevent it from ever entering the if statement?
First, you pass wrong variable into Split function
See help. This would be a string expression not a variant
Try this one, seems to be working for me
~'J'~
Option Explicit
Function stringToDblArray(expStr As String)
Dim i As Integer
Dim VarPoints
VarPoints = VBA.Split(expStr, ",")
Dim check As Boolean
check = False
If IsNumeric(VarPoints(i)) Then
check = True
Next
If check = True Then
ReDim fstAr(UBound(VarPoints)) As Double
fstAr(i) = CDbl(VarPoints(i))
Next i
stringToDblArray = fstAr
Else
ReDim SndAr(UBound(VarPoints)) As String
SndAr(i) = CStr(VarPoints(i))
Next i
stringToDblArray = SndAr
End Function
Sub test()
Dim a As String, b As String, c, d
a = "1,2,3,4,5"
b = "a,b,c,d,e"
c = stringToDblArray(a)
d = stringToDblArray(b)
If VarType(c) = vbArray + vbDouble Then
MsgBox "First Returned Array Is An Array of Doubles"
If VarType(d) = vbArray + vbString Then
MsgBox "Second Returned Array Is An Array of Strings"
End Sub
