ques re help file examples - don't set objs to nothing?
On the subject of setting object variables to nothing when they're no longer
needed, I have looked at many help file code examples on diff subjects and
not found any that follow that rule. Is that intentional to teach us
beginners bad programming manners?
related ques: is this a different case?
Function MirrorObjSet(objSet, mirrptarr)
Dim obj1 As AcadEntity
For Each obj1 In objSet
...do something with obj1...
next obj1
end sub
Here, obj1 was never set using the 'Set' command?/keyword?/function?
so does it still need set to nothing at the end or is this different?
[email protected]
A.T. Renczarski and Co., inc.
p 816.587.0101
f 816.587.5691
Hi Mark. Tis example is indeed a bit different. When using For Next to iterate a set of objects,
the iterator is automatically pointed at the next object in the collection.
Mark Propst wrote in message ...
> next obj1
> end sub
> [email protected]
> p 816.587.0101
> f 816.587.5691
Sender IP : 208.225.248.186
Sender Host : no reverse DNS for this IP
Posted by newsgroup Xplorer : http://connect.to/newsgroup | http://www.newsgroupxplorer.com
Thanks again for answering,
Frank Oquendo wrote in message
news:[email protected]...
collection.
So an iterator even tho it points to an object does not need to be set =
nothing
after pointing to the last object in the collection it doesn't remain stuck
there, it goes out of scope automatically like and int or double etc
variable?
Mark
> So an iterator even tho ...
That's correct. One thing to keep in mind is that you can't ever go
wrong by setting an object to Nothing so long as it's an object you
created. So even though you don't *have* to clear the iterator object
(or any other object for that matter), it's perfectly ok to do so.
http://www.acadx.com
"You keep using that word. I do not think it means what you think it
means."
"Mark Propst" wrote in message
Next to
> collection.
set =
> nothing
remain stuck
> variable?
> Mark
Thank You.
