Pure Virtual Function Call Error #R6205
Message 1 of 12
I have noticed a few others have been seeing this error message pop up on
occasion. Does anyone have a solution to this yet? I searched the AutoDesk
Knowledge Base, but no solutions.
The exact error occurs as follows:
Upon exiting AutoCAD, a message box appears with the following message:
MicroSoft Visual C++ Runtime Library
Runtime Error C:\Program files\AutoCAD2002\acad.exe
Error # R6025
TIA,
Rob
Replies (11)
Message 2 of 12
I get this from time to time when I have application and/or document level
event reactors running. It is intermittent though. I know it isn't a
solution, but it may help point to the cause.
Chuck
"Rob Outman" wrote in message
news:[email protected]...
AutoDesk
> Error # R6025
> TIA,
> Rob
Message 3 of 12
I have the same trouble. It seems to have something to do with the registry.
That's all I know. : (
"Chuck Gabriel" wrote in message
> Chuck
on
> AutoDesk
> > Error # R6025
> > TIA,
> > Rob
Message 4 of 12
Rob,
This error occurs when an application indirectly calls a pure virtual member
function in a context where a call to the function is not valid. In most
cases, the compiler detects this and reports the error when building the
application. But depending on how the code is written, sometimes the problem
is detected only at run-time. The error occurs when you indirectly call a
pure virtual function within the context of a call to the constructor or
destructor of an abstract base class. Calling a pure virtual function is a
programming error, so Autodesk would need to find the call to the pure
virtual function and rewrite the code so it is not called.
My hunch is that this error is only being fired when AutoCAD is shutting
down (call to the destructor of the abstract base class)...after the
drawings have been closed. I don't think that there is any harm in simply
ignoring the error.
Wayne
AutoDesk
> Error # R6025
> TIA,
> Rob
Message 5 of 12
"Wayne Craig" wrote in message
> Rob,
member
problem
It's usually a good idea to quote the source that
you're quoting or paraphrasing (the MSDN online docs
for the R6205 error in this case).
My hunch is that Autodesk is already well aware of
problem, knows where it is, but isn't talking and
doesn't intend to fix it.
Message 6 of 12
I get this error all the time! And yes, it is ONLY when i am shutting down
Autocad (or sometimes just closing a drawing).
I ignore it and there doesnt seem to be any lingering problem.
But it is pretty sad that it is frequent.
"Tony Tanzillo" wrote in message
> > Rob,
> member
> problem
a
a
Message 7 of 12
I had the same report here, but it seemed to be only on a Windows XP
machine...
Brian D.
AutoDesk
> Error # R6025
> TIA,
> Rob
Message 8 of 12
Saw my first one today. Win98, R2002, no reactors running.
Joe
AutoDesk
> Error # R6025
> TIA,
> Rob
Message 9 of 12
I get it quite often. It's almost a part of closing Acad now. In my case,
it's not reactor related, 'cause I've only recently started playing with
reactors.
AcadMap 2000i, Win98.
Rob Outman wrote in message
AutoDesk
> Error # R6025
> TIA,
> Rob
Message 10 of 12
I mostly see this problem when working with 3D objects and deleting them but have seen this when closing drawings. I work in a fast paced company and this error happens to me at least 3 times a week which slows down my production time. I've tried taking different steps when working with 3D objects but it only puts a band aid over the problem for now, meaning it still happens just not as much.
Message 11 of 12
hey. i was wondering if you could help me.. so i received this runtime error when i was trying to play a game i installed.. now i'm not to computer savvy can you explain to me a way to fix this? i really hope you can help. i don't want to sit on the phone for hours with someone..
please e-mail me.. [email protected]
thank you
angela
Message 12 of 12
I've been getting this same message when I try to open AutoCAD and its shutting the program down. I can't do any work.
