progression bars
progression bars
progression bars
hi
i am trying to place a progression bar in my program, however, i am having
difficulty in showing the progression bar and having stuff run to make the
progression, it seems that i have to close the progression bar userform
before the other subs run..... please help
thanks in advance
cheers
mark
Add "do events" to your code and the other events will continue to run.
"Mark Dubbelaar" wrote in message
news:B2F3CFA9119A4B0FBD87DEF2ACE6E51C@in.WebX.maYIadrTaRb...
> hi
> thanks in advance
> cheers
> mark
It seems that you put the progress bar on a UserForm and you display the
UserForm like this:
UserForm.Show.
Unfortunely, in ACAD VBA, UserForm is opend as modal form by default, hence
your program stops until the modal form is closed.
You can
1. open the UserForm as a modeless form if you use AutoCAD 2000i or later.
2. Put your operation executed by the program in the UserForm's
UserForm_Activate( ) event procedure, that is, once the progres bar is
displayed, the process starts. Then when the process finished, unload the
UserForm.
> hi
> thanks in advance
> cheers
> mark
Try this weblink
http://www.vbdesign.net/cadpages/files/pbar.htm
"Norm Yuan" wrote in message
news:C0F9F98312059A261935FFEA583AD544@in.WebX.maYIadrTaRb...
> UserForm like this:
> UserForm.Show.
hence
> You can
> UserForm.
> > hi
having
the
> > thanks in advance
> > cheers
> > mark
