disable default reactors ???
Hi there.
I have writen a vb program that edits the attributes in a block.
I am have trouble with trying to overwrite the default AutoCAD function that
is called up when you
double click a block.
I want to double click my block and run my edit program. not AutoCAD's
attedit one can you help please.
I have already tried a reactor program using Vlisp and writing a double
click event
they do work but not on things already assigned an AutoCAD function.
Do you have any Ideas
Regards Stuart.
just undefine the original command
(command "UNDEFINE" "attedit")
(defun c:attedit()
(command "-VBARUN" "module??.????")
???=your command-name
dblclkedit
off
Bobby C. Jones
http://www.acadx.com
