Programming dynamic blocks
I'm wondering if it is feasible to define a dynamic block and insert it with
code to set the parameters.
In the simplest case I'm thinking about I would have two parallel sides
joined at each end by a 180 degree arc.
I would wish to insert the block and define the side lengths and the width
between sides - which would force the arc radius to change accordingly.
For convenience the insertion point would be the mid point of one of the
arcs.
Any comments and thoughts appreciated.
Laurie Comerford
www.cadapps.com.au
Perhaps a class would be helpful. I have built rectangle classes in the
past that contained a Draw method that took parameters for corner point,
width, and height. Other methods returned a center point, filleted corners,
etc. When the instance went out of scope, an ordinary LWPoly was left in
the drawing Your class could leave the block.
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
"Laurie Comerford" wrote in message
news:4860170@discussion.autodesk.com...
arcs.
Laurie Comerford
www.cadapps.com.au
