Problems selection set
I am having some problems using selection sets correctly.
I have written a function which is supposed to check and see if there is any
text within a given rectangle. Basically I am using this to make sure that
I don't write text over existing text, so when I create a new piece of text
I send the bounding box of the new text to this function - if there is
already text anywhere in the box then I either delete the potential new text
or move it somewhere else.
The problem is that the selection set does not work consistently. Sometimes
it never picks up anything in the crossing (even though I know there is text
in the crossing during debug) and sometimes is does work. I am guessing it
has something to do with the creation of the selection set object, resetting
and scope?
After the code fails sometimes in the same session it will suddenly work?
As well, I am not too experienced in the use of On Error ? Sometimes I get
an error indidcating that the selection set already exists so I inserted the
On Error line (which is now commented out).
Can anyone point me in the right direction?
Natan Elsberg
The function:
Public Function IsTextInRectangle(corner1 As Variant, corner2 As Variant) As
Boolean
Dim ssetObj As AcadSelectionSet
Dim aobject As AcadObject
Dim aline As AcadLine
'On Error Resume Next
Set ssetObj = oacadApp.ActiveDocument.SelectionSets.Add("zzzzSSET")
Dim bAnswer As Boolean
bAnswer = False
Dim mode As Integer
mode = acSelectionSetCrossing
ssetObj.Select acSelectionSetCrossing, corner1, corner2
'Set aline = moSpace.AddLine(corner1, corner2)
For Each aobject In ssetObj
If aobject.ObjectName = "AcDbText" Then bAnswer = True
Next
ssetObj.Delete
IsTextInRectangle = bAnswer
End Function
What happens if you omit the On Error Resume Next statement?
- Tom
Natan Elsberg wrote in message
news:F296CD1DBE41B848E4DF5AC7651C846B@in.WebX.SaUCah8kaAW...
> Hi,
there is any
sure that
of text
is
new text
Sometimes
is text
guessing it
resetting
> and scope?
work?
Sometimes I get
inserted the
> Thanks,
> Natan Elsberg
> The function:
Variant) As
> Boolean
> bAnswer = False
> Dim mode As Integer
> Next
> ssetObj.Delete
> End Function
The select method of selectionsets works with the display list (that is,
the list of objects in the display) in stead of the real list of entities
in your drawing. If you can't see an object in the display, probably the
select method will not select it.
One option to solve this, which is more a workaround, is to use the command
ZoomExtents before you use ssetObj.select.
This is one of the unfortunally aspects of selection sets which limits the
use of it.
wkr, jwk
Natan Elsberg had the next bright idea:
>Hi,
>any text within a given rectangle. Basically I am using this to make
>sure that I don't write text over existing text, so when I create a new
>piece of text I send the bounding box of the new text to this function -
>if there is already text anywhere in the box then I either delete the
>potential new text or move it somewhere else.
>Sometimes it never picks up anything in the crossing (even though I know
>there is text in the crossing during debug) and sometimes is does work.
>I am guessing it has something to do with the creation of the selection
>set object, resetting and scope?
>work? As well, I am not too experienced in the use of On Error ?
>Sometimes I get an error indidcating that the selection set already
>exists so I inserted the On Error line (which is now commented out).
>Thanks,
>Natan Elsberg
[snip]
jwk,
I checked it out and you are right!
I placed some text on my own where I knew my application would place text.
In those spots only the text did not appear.
Meaning that the text entities that I created previously in my procedure are
not recognized by the selection set!!!
I don't think a zoom extents would be appropriate to solve my problem (as
this routine may iterate hundreds of times). Any other thoughts?
Natan
jwk wrote in message
news:8FD8E8475aoposhotmailcom@167.216.240.240...
command
> use of it.
> wkr, jwk
> >Hi,
> >Thanks,
> >Natan Elsberg
> [snip]
