Problem with SelectionSets
Message 1 of 11
the code of my procedure is:
Public Function GetLayerEnts(sLayrName As String) As AcadSelectionSet
Dim iType(0) As Integer
Dim vData(0) As Variant
Dim sSet As AcadSelectionSet
On Error Resume Next
Set sSet = MyDrawing.SelectionSets("sel" & sLayrName)
If err Then Set sSet = MyDrawing.SelectionSets.Add("sel" & sLayrName)
sSet.Clear
iType(0) = 8
vData(0) = sLayrName
sSet.Select acSelectionSetAll, FilterType:=iType, FilterData:=vData
If Not sSet Is Nothing Then
Set GetLayerEnts = sSet
End If
End Function
I call this procedure more than 60 times(one for each layer of my drawing) and there is one momment in which Sset returns Nothing despite there should be entities in the selection set. I don't know why this is happenning.
Please, can anybody help me?? it's driving me crazy.
Replies (10)
Message 2 of 11
Give this a try ...
Dim LayerName As String
LayerName = "sel" & sLayrName
ThisDrawing.SelectionSets(LayerName).Delete
Set sSet = ThisDrawing.SelectionSets.Add(LayerName)
iType(0) = 8
vData(0) = LayerName
If sSet.Count Then
End If
End Function
Public Sub Test()
Dim oLayer As AcadLayer
Dim oSS As AcadSelectionSet
For Each oLayer In ThisDrawing.Layers
Set oSS = GetLayerEnts(oLayer.Name)
If Not oSS Is Nothing Then
MsgBox oLayer.Name & " Count: " & oSS.Count
Else
MsgBox oLayer.Name & " Count: 0"
End If
Next oLayer
End Sub
Joe
wrote in message news:5196604@discussion.autodesk.com...
sSet.Clear
iType(0) = 8
End If
End Function
Message 3 of 11
it's the same...
the problem is, I don't know why, that
returns sset=nothing though my drawing has entities in the layer in which is trying to get the selectionset.
It happens after an undetermined number of selections... I have read in other post that acad only allows 120 selectionsets, but I think that if I destroy de object after each processed layer, that shouldn't be the problem.
Thank very much you for you reply anyway.
Message 4 of 11
In your original code you are not destroying the named selection set like I
am in my code.
Did you try my code on your drawing?
Can you send me the drawing directly [don't post on newsgroup]?
Joe
wrote in message news:5196698@discussion.autodesk.com...
it's the same...
Message 5 of 11
mdhutchinson
Joe... I am one of perhaps many that have gained good help from your book and from you directly as well ... at one point you had said that you'd be willing to help (of course on a limited bases)... How can I find your email address?
Message 6 of 11
If you are using Outlook Express as a reader then reply to sender would give
you that info or
joesutphin@earthlink.net
wrote in message news:5196848@discussion.autodesk.com...
address?
Message 7 of 11
Setting the SSet variable to nothing does not "delete" the selectionset, but removes a reference to it.
Before setting the variable to nothing, do the .Delete method is it. This will delete the selection set (considering that the 120 selectionset max is you problem)....
Message 8 of 11
Try this one. works for me nice
Option Explicit
Public Function GetLayerEnts(ByVal sLayrName As String) As AcadSelectionSet
LayerName = sLayrName ''=>problem was here
For Each sSet In ThisDrawing.SelectionSets
If sSet.Name = LayerName Then
sSet.Delete
Set sSet = Nothing
Exit For
End If
Next sSet
iType(0) = 8
sSet.Select acSelectionSetAll, , , iType, vData
If sSet.Count > 0 Then
End If
End Function
''test part by Joe Sutphin
Public Sub Test()
Dim iCount As Integer
iCount = oSS.Count
MsgBox oLayer.Name & " Count: " & iCount
Else
End If
Next oLayer
End Sub
Fatty
~'J'~
Message 9 of 11
Note all the examples here use On Error Resume Next without a corresponding On Error GoTo 0 statement. It is good practice to stop Error Trapping with the On Error GoTo 0 statement straight after the code you expect may error.
Regards - Nathan
Message 10 of 11
I thought I would add my approach to the mix.
I have a function that creates the next available selectionset based upon a naming convention of "SSET" and a incremented number.
I create the selection set using this function and then delete it as soon as I am finished with it.
Public Function CreateEmptySSet() As AcadSelectionSet
Dim blnExists As Boolean
Dim intCount As Integer
Dim strName As String
Dim objSSet As AcadSelectionSet
blnExists = True
intCount = 0
Do Until blnExists = False
blnExists = False
intCount = intCount + 1
strName = "SSET" & intCount
For Each objSSet In ThisDrawing.SelectionSets
If UCase(objSSet.Name) = strName Then blnExists = True
Next objSSet
Loop
Set CreateEmptySSet = ThisDrawing.SelectionSets.Add(strName)
End Function
Regards - Nathan
Message 11 of 11
excelent point Nathan, thnks!
wrote in message news:5197802@discussion.autodesk.com...
Regards - Nathan
