Problem with add selection
I want add an entity in a selection set only if this entity
have a determinated layer.
My wrong routine:
Dim SelObj As AcadSelectionSet
Dim Ent As AcadEntity
Dim EntAgg(0 To 1) As AcadEntity
Dim NameLayer As String 'name of the guide layer
..make a selection set
For Each Ent In SelObj
If Ent.Layer = NameLayer Then
Set EntAgg(0) = ThisDrawing.SelectionSets.Item(Ent)
SelParz.AddItems EntAgg
End If
Next Ent
Thx and sorry for my bad english
Use a filter to selection entities on the layer you're interested in.
Public Sub createSelectionSet()
Const TARGET_LAYER_NAME = "0"
Dim selectionSet As AcadSelectionSet
Dim filterType(0) As Integer
Dim filterData(0) As Variant
For Each selectionSet In ThisDrawing.SelectionSets
If selectionSet.Name = "TEST" Then
selectionSet.Delete
Exit For
End If
Next selectionSet
filterType(0) = 8
filterData(0) = TARGET_LAYER_NAME
Set selectionSet = ThisDrawing.SelectionSets.Add("TEST")
selectionSet.Select acSelectionSetAll, , , filterType, filterData
MsgBox "Number of entities selected: " & CStr(selectionSet.Count)
selectionSet.Delete
End Sub
