Problem with acCTRL
Problem with acCTRL
Problem with acCTRL
Hi !
I'm using that component. It's very good to my routines. But a problem has happened: When I put mouse on graphical environment and press key F2, so it 's lunching  total cad to front my application. Is it possible avoid that happen ?
I want to say, disable F2 from autoCad ? I'm using 2010 version.
Thanks !
Nobody knows ?
I 'd like a simple direction.
Thanks !
andrewpuller3811
Try looking up "shortcut keys" in the help.
In the CUI editor you can assign the "Cancel" which contains "^C^C" in the macro to the "F2" Key.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Thanks! I'll try !
Hi Andrew, unhappylli I did not get yet.
andrewpuller3811
What did you try? Write out the steps.
Maybe attach a screen shot.
Andrew Puller
Windows 11
Civil 3d 2023
