Print to pdf from an excel
shuaib_cad
shuaib_cad
I have a list of drawing numbers which I have placed in an excel with their location intact. I want to convert all of them into PDFs through VBA excel macro.
Currently I am using the below code but it isn't working for me:
Sub ConvertToPDF()
Dim oWkbk As Workbook
Set oWkbk = ThisWorkbook
Dim oSheet As Worksheet
Set oSheet = oWkbk.ActiveSheet
sFilepathRange = "O2:O50"
Dim oAcadApp As Object
Dim oAcadDwg As AcadDocument
Set oAcadApp = CreateObject("Autocad.Application")
oAcadApp.Visible = True
Dim sFilePath As String
'oAcadApp.Documents.Close
For Each oCell In oSheet.Range(sFilepathRange)
If oCell <> "\.dwg" Then
Set oAcadDwg = oAcadApp.Documents.Open(oCell, True)
'oAcadDwg.ActiveLayout.UseStandardScale = True
'oAcadDwg.ActiveLayout.StandardScale = acScaleToFit
'oAcadDwg.ActiveLayout.PlotRotation = PlotRotation
'oAcadDwg.ActiveLayout.StyleSheet = "monochrome.ctb"
'oAcadDwg.ActiveLayout.ConfigName = "PDF-XChange 4.0 Lite"
'oAcadDwg.ActiveLayout.CanonicalMediaName = "Letter"
'oAcadDwg.ActiveLayout.PlotType = acExtents
'oAcadDwg.Plot.PlotToDevice
End If
Next
oAcadApp.Quit
Set oAcadApp = Nothing
MsgBox "Converted to PDF"
End Sub
Please help me with the correct code.
Mohammed Shuaib
grobnik
Hi @shuaib_cad could you explain where your code hangs ? or what's wrong for your application ?
Seems you are opening the dwg but not plot due to  you have commented the plot command.
shuaib_cad
I need code to print the drawings into pdf. The existing code which I have commented is not working for me as I get error in the line:
End If
Next
and its not moving to the next drawings.
grobnik
Hi @shuaib_cad , as first step I suggest to run the procedure step by step, check all the variable, check if drawing will be opend, check the filename.. and so on.
As second issue fix the following row
With
Set oAcadDwg = oAcadApp.Documents.Open(oCell.value, True)
If you wirte "Ocell" only, instead "oCell.Value", perhaps will be not passed the cell value only with file name and or path, but all cell properties content in the oCell object.
Let us know in case share the excel file, and at least one or two dwg for test.
Thank you.
