populating a listbox with text in a txt file.
Message 1 of 8
(im learning)
I would like my vb prog to read a txt file and populate a listbox.
The items in a txt file will be added to from time to time.
I appreciate your help.
thanks
Replies (7)
Message 2 of 8
Assuming each line in the text file is to become one line in a list box:
Create a file called "sample.txt" and save it in your TEMP folder on C:
drive. Here's the data I used (you can use whatever you like):
Line 1
Line 2
Line 3
Line 4
Line 5
Enter the VBAIDE, add a UserForm. Place a listbox on the UserForm and place
this code in the UserForm's Initialize event (fair warning; there's *no*
error checking):
fh = FreeFile
Open "c:\temp\sample.txt" For Input As #fh
Do While Not EOF(fh)
Line Input #fh, tmp
ListBox1.AddItem tmp
Loop
Close fh
Run the form and the contents of the text file will be placed in the list
box.
Attitudes are contagious. Is yours worth catching?
http://www.acadx.com
Jeremy wrote in message
news:[email protected]...
> (im learning)
> thanks
Message 3 of 8
Thanks, I was hoping someone else was awake out there.
Frank Oquendo wrote in message
> Line 1
> Line 2
> Line 3
> Line 4
> Line 5
place
> error checking):
> fh = FreeFile
> Line Input #fh, tmp
> Loop
> Close fh
> box.
> > (im learning)
> > thanks
Message 4 of 8
Can you explain to me why you used the "#fh" instead of #1 or any other number for that matter?
Would it work the same if it were #1, #2, etc.?
Message 5 of 8
You generally would use a style similar to the following:
Dim File As Integer
'get a handle to file
File = FreeFile
'write the Text to file
Open strFilename For Append Access Write As #File
Write #File, "Text objects"
'write each Text object to file
For Each objAcadText In objSelectionSet
Write #File, TextString
Next objAcadText
Close #File
Personally, I would opt using the Microsoft FileSystemObject for tasks such
as this.
Joe ...
wrote in message news:[email protected]...
Message 6 of 8
And the opposite would be the following:
Dim File As Integer
Dim TextLine As String
File = FreeFile
Open strFilename For Input Access Read As #File
Do While Not EOF(File)
Line Input #File, TextLine
MsgBox TextLine
Loop
Close #File
Joe ...
"Joe Sutphin" wrote in message
Dim File As Integer
File = FreeFile
Next objAcadText
Close #File
as this.
Joe ...
Message 7 of 8
Hi Joe,
What do you see as the advantage of the FSO compared with the VB method?
I looked in your book for a reference to it, but found nothing.
Regards
Laurie Comerford
> Dim File As Integer
> File = FreeFile
> Next objAcadText
> Close #File
> as this.
> Joe ...
Message 8 of 8
I was surprised at that too
FSO is universally denigrated on the "real" vb groups
security issues, bloated object being stated as the two reasons not to use
it.
mark
"Laurie Comerford" wrote in message
Hi Joe,
Regards
Laurie Comerford
> such
> as this.
> Joe ...
