POLYLINE
POLYLINE
Message 1 of 11
POLYLINE
I have a richtext box that has contains
X,Y
X,Y
X,Y
X,Y
X,Y
and I would like to create a polyline from the X,Y's in the richtextbox.
Any Ideas? It needs to be a continuas polyline.
Replies (10)
Message 2 of 11
I'd bet the appropriate method has Polyline in its name and guarantee there is a sample in the
help menu... So I assume that's not your question - what exactly are you having trouble with?
wrote in message news:5870481@discussion.autodesk.com...
X,Y
X,Y
X,Y
X,Y
X,Y
Message 3 of 11
I am having trouble asigning all of the X,Y's to the POLYLINE and then drawing the long polyline?
Message 4 of 11
I won't guess - post the relevant code...
wrote in message news:5870483@discussion.autodesk.com...
Message 5 of 11
Set ObjPolyline = Thisdrawing.modelspace.AddPolyline (Richtextbox1.text)
Note: The RichTextbox is multiline and the contents are
X,Y
X,Y
X,Y
X,Y
X,Y
X,Y
I also have a string named TEMPSTRING
TEMPSTRING = X,Y,X,Y,X,Y,X,Y,X,Y
The above doesn't work.
I need a continuous polyline using either the Richtextbox1.text contents OR by using the TempString
Message 6 of 11
I think I need to create an point array from the TEMPSTRING or TEXTBOX but I don't know how.
Message 7 of 11
Try this one
Option Explicit
Dim ar As Variant
Private Sub CommandButton2_Click()
Dim st As String
st = RichTextBox1.Text
ar = Split(st, vbCr)
ReDim Preserve ar(UBound(ar) - 1)
Dim cnt
Dim i
ReDim coors(0 To (UBound(ar) * 2) + 1) As Double
For i = 0 To UBound(ar)
Dim tmp
tmp = Split(ar(i), ",")
coors(cnt) = CDbl(tmp(0))
cnt = cnt + 1
coors(cnt) = CDbl(tmp(1))
cnt = cnt + 1
Next i
ThisDrawing.ModelSpace.AddLightWeightPolyline coors
End Sub
~'J'~
Message 8 of 11
[code]
Sub driver()
Dim pl As AcadLWPolyline
Set pl = ThisDrawing.ModelSpace.AddLightWeightPolyline _
(StringToDoubleArray("1,1,2,2,0,2"))
pl.Closed = True
End Sub
Function StringToDoubleArray(inString As String)
'you could avoid using split and just loop
'the string but you would need to keep calling
'redim. Would be good practice to try looping
'the string though. Look into VBA.Mid, VBA.Len, ...
Dim strArr
strArr = VBA.Split(inString, ",")
ReDim dblArr(UBound(strArr)) As Double
Dim i As Integer
For i = 0 To UBound(strArr)
If VBA.IsNumeric(strArr(i)) Then
dblArr(i) = strArr(i)
Else
'Solve the problem
Next i
StringToDoubleArray = dblArr
End Function
[/code]
wrote in message news:5870504@discussion.autodesk.com...
X,Y
X,Y
X,Y
X,Y
X,Y
X,Y
Message 9 of 11
You could also use a Collection as your container which dynamically resizes itself.
This version would also take any or no delimiter.
[code]
Function StringToDoubleArray(inString As String) As Double()
Dim dblColl As New Collection
Dim i As Integer
For i = 0 To VBA.Len(inString)
If VBA.IsNumeric(VBA.Mid(inString, i + 1, 1)) Then
dblColl.Add VBA.Mid(inString, i + 1, 1)
Next i
ReDim scratch(dblColl.Count - 1) As Double
For i = 0 To dblColl.Count - 1
scratch(i) = dblColl(i + 1)
Next i
StringToDoubleArray = scratch
End Function
[/code]
"Paul Richardson" wrote in message news:5870497@discussion.autodesk.com...
[code]
Sub driver()
pl.Closed = True
End Sub
Dim strArr
Dim i As Integer
Else
'Solve the problem
Next i
End Function
[/code]
X,Y
X,Y
X,Y
X,Y
X,Y
X,Y
Message 10 of 11
Thanks everyone but I still doesn't seem to work. Instead of my program building a string or populating a richtextbox is there a way to have it populate an array? vars = XXX and YYY
Message 11 of 11
Thank you all. Got it to work with a little editing.
God bless
