all AutoCad COMMANDS
I was just wondering if someone has a list that shows all BASIC AutoCad commands for VBCODE? Example:
Thisdrawing.ZOOMEXTENTS
Thisdrawing.LINE
Thisdrawing.ERASE
Thisdrawing.Circle
I am just guessing on the above. But I feel like there should be a list someone. Please post.
In the VBA IDE if your IDE is set to autolist members (Tools, Options, and check Auto List Members) you can see a list.
There are no basic AutoCAD commands for VB code.
You can only execute commands using the SendCommand() method of the AcadDocument.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5870422@discussion.autodesk.com...
Thisdrawing.LINE
Thisdrawing.ERASE
Thisdrawing.Circle
dgorsman
Help file lists both method and property members for the various objects. You need to adjust your direction of thinking away from command-line intput and into the programmatic methods.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
While what Tony advised is true and sending AutoCAD commands is an
inefficient way of programming the basic Zoom commands are available in VBA
and can be run directly without have to reference the Object they refer to
in the code.
ZoomAll
ZoomCenter
ZoomExtents
ZoomPickWindow
ZoomPrevious
ZoomScaled
ZoomWindow
Regards
Laurie Comerford
"Tony Tanzillo" wrote in message
news:5870435@discussion.autodesk.com...
AcadDocument.
wrote in message
Thisdrawing.LINE
Thisdrawing.ERASE
Thisdrawing.Circle
