PolyLine LineWeight
PolyLine LineWeight
PolyLine LineWeight
I am trying to change the thickness of a lightweighPolyLine programmatically with VBA. I am using the following code:
oPline.Lineweight = acLnWt005
Where "oPline" is the polyline object. When I run this, the lineweight doesn't change at all. Is there some other factor involved here that I'm not aware of? Any help would be greatly appreciated.
I guess you need to set LWDISPLAY
system variable to 1:
Option Explicit
Sub test()
Dim oent As AcadEntity
Dim varPt
Dim oPline As AcadLWPolyline
ThisDrawing.SetVariable "LWDISPLAY", 1
ThisDrawing.Utility.GetEntity oent, varPt, "Select pline"
Set oPline = oent
oPline.Lineweight = acLnWt120
oPline.Update
End Sub
And another one:
acLnWt005 value is to small, maybe
you need to play with bigger values
say use acLnWt050
Hth
~'J'~
