Plot issues with VBA
Jonathan3891
Advisor Advisor
Jonathan3891
Hey everyone.
I am working on a vba plot tool that I am having a few issues with.
I was having trouble setting the paper size and after a ton of searching I found the "blad" section of coding which seems to be working with the exception of the sheet style. Maybe it should be plotstyle?
My other main issue is that when I run this module, it takes 30 seconds or so before it prints. What is causing the delay? I have no loops or arrays, so I'm not sure why its taking so long.
Public Sub Plot_11x17()
Dim PntrName As String
Dim CTBhalf As String
Dim blad As AcadLayout
PntrName = UserForm1.PntrName.Value
CTBhalf = UserForm1.CTBhalf.Value
'Set Values
Set blad = ThisDrawing.Layouts.Item(layout1)
ThisDrawing.ActiveLayout = blad
blad.ConfigName = PntrName
blad.CanonicalMediaName = "11x17"
blad.PlotType = acExtents
blad.CenterPlot = True
blad.StandardScale = acScaleToFit
blad.ScaleLineweights = False
blad.StyleSheet = CTBhalf '<<<<<<<<<<<<<<<<<<< not working!!!!!!!!!!
blad.PlotWithPlotStyles = False
blad.PlotWithLineweights = fasle
'Set Number of Copies
ThisDrawing.Plot.NumberOfCopies = 1
'Initiate Plot
ThisDrawing.Plot.PlotToDevice
End Sub
Jonathan Norton
Blog | Linkedin
Ed__Jobe
You need to add the file extension, e.g. CTBhalf.ctb. The delay could be caused by acad searching all the paths looking for the file.
Ed
How to post your code.
Jonathan3891
Thanks for your reply Ed.
I have a userform that uses "GetPlotStyleTableNames" to get the ctb names and the name is passed to the module with
So in theory the code should be reading "CMS_b_black.ctb", correct?
Jonathan Norton
Blog | Linkedin
Ed__Jobe
Easy to find out. Set a breakpoint and step through the code and inspect the variable.
Ed
